  #41
Old 02-08-2007, 07:53 PM
hummer74's Avatar
hummer74 hummer74 is offline
hummer74 is on a distinguished road
Default Re: before and after, or this morning and afternoon
Originally Posted by SHYANNE
so what size toyos are you running on the stock wheel ?
are you asking me? if you are, i am running 37 inch tires. official spec of the tire is 37X13.5X17, and yes it's the stock wheel just powdercoated black. the powdercoating cost me $55 a wheel.
and thanks dennis.
Formerly Saleen779
Old 02-09-2007, 03:22 PM
GLBLWARMR's Avatar
That is one awsome transformation.
He has done a great job with it.
2006 H2 w/6 inch lift.
2001 F-350 w/10 inch lift
2013 Victory Cross Country
2006 Suzuki Hayabusa
Old 02-09-2007, 09:15 PM
hummer74's Avatar
thanks again everyone.
well here's an update. my buddy owns a firetruck shop in denton and he helped me out with moving the airbag sensor and cutting the lip on that one piece. here a some pics showing the final product, i havent painted the shiny parts yet.
Formerly Saleen779
Old 02-09-2007, 09:17 PM
hummer74's Avatar
we went ahead and flipped the lower part as well, that was VERY easy. actually, we swapped the the whole arms from the left side of the vehicle to the right and vice versa. turned out great and lots more clearance. all in all, took about 30 minutes to do all of it.
Formerly Saleen779
Old 02-09-2007, 09:55 PM
H2 BULLY's Avatar
H2 BULLY H2 BULLY is offline
Awesome, what size and type of Screw did you use for both the top and bottom?
T & A RULES ESCALATOR
Kiss my AXLE
Old 02-09-2007, 10:29 PM
hummer74's Avatar
lol, i knew someone would ask. to be honest i have no idea. but it really didn't matter, because, you need to cut the remaining plastic post off, you can drill any size hole you want into the arm and put whatever size you want in there. i actually didn't even use a screw, we used a phillips head domed bolt and locknut. you just drill the hole to whatever size you are going to use. and for the bottom, you use the stock bolt thats already on there. hope that helps. if you have any questions when you are doing it, i can pm you my phone number to walk you through it.
Formerly Saleen779
Old 02-09-2007, 10:35 PM
hummer74's Avatar
HOPE THIS HELPS. I CAN USE PAINT TOO DOC!
Formerly Saleen779
Old 02-09-2007, 11:57 PM
obzidian's Avatar
obzidian obzidian is offline
obzidian is on a distinguished road
truck looks great.... you think you could possibly just reuse that hard plastic pin that comes with the sensor or you had no choice to modifiy it?
Old 02-10-2007, 12:02 AM
hummer74's Avatar
yes, if you can figure out how to get if off without breaking it. i just didnt want to mess with it, so we cut if off.
Formerly Saleen779
Old 02-12-2007, 05:27 AM
hummer74's Avatar
ok, i found out what the bolt is.
it is a 5/16 stainless steel x 1.250 phillips panhead bolt with a stainless steel nylock nut. that bolt fits perfectly through the rubber link. hope that helps you all.
Formerly Saleen779
Old 02-12-2007, 06:07 AM
H2 BULLY's Avatar
Thanks I am going to do the switch some time this week.
Kiss my AXLE
Old 02-12-2007, 07:15 AM
Sportsdude's Avatar
Sportsdude Sportsdude is offline
Sportsdude is off the scale
Nice rig
2005 H2 SUV (Yellow)
2003 Vert Supercharged
Old 02-12-2007, 03:40 PM
hummer74's Avatar
thanks sports dude.
h2bully, be sure to post up some pics when youre done!
Formerly Saleen779
Old 02-12-2007, 07:55 PM
H2 BULLY's Avatar
DONE My hubby did a little how to with pics, it is in the H2 tech discussion.
Kiss my AXLE
Old 02-12-2007, 07:59 PM
Bully13's Avatar
Bully13 Bully13 is offline
http://www.elcovaforums.com/forums/s...ad.php?t=24657
Old 04-18-2007, 04:50 AM
mrlittle's Avatar
mrlittle mrlittle is offline
mrlittle is on a distinguished road
what model number are those piaa's and did they wire into old lights harness?
Old 05-07-2007, 03:40 AM
hummer74's Avatar
i believe they are the piaa 520's but dont quote me on that. install was simple if u have factory wiring already there. just cut the old plugs from the old lights and solder on the piaa plugs and then wrap up the connection. that was it. i had mine done at cartoys for me, it was like $50 or something....pretty cheap and they did a better job than i would have.
Formerly Saleen779
Old 05-08-2007, 11:10 PM
H2BRUTE H2BRUTE is offline
Location: GAIN INFORMATION AND EDUCATION RELATING TO HUMMER H2\'S
H2BRUTE is off the scale
Looks like one bad H2..Great job. Especially like the pic from ground level showing off them monster tires...Love the H2. You can personalize it to your hearts content and most of the time, they look great whether you are a blinger or off roader......Da Brute
