Old 02-12-2007, 07:47 PM
Bully13's Avatar
Bully13 Bully13 is offline
Default Air ride sensor mod made easy!
Bullies in the Garage Present:
Air ride sensor modification made easy!
So your thinking of buying 37's for your H2 but you are worried about breaking your control arm air ride sensor. Well, the Bullies are here to show you how to make it easy and affordable.
Cost of this project: 75 cents
Tools needed:
Drill,
5/16 drill bit,
Wire Cutters,
Cresent Wrench,
Monkey Wrench,
(and my personal fav...)
Henckels Brand Steak Knife
Old 02-12-2007, 07:50 PM
Bully13's Avatar
Default Re: Air ride sensor mod made easy!
The first thing you need to do is purchase two Carrage Bolts 5/16 x 1 1/4
as well as two locking nuts.
Old 02-12-2007, 07:53 PM
Bully13's Avatar
The next thing to do is to cut off the end of that pin on the control arm using a steak knife or anything else you can use to make a clean cut. (The steak knife was fast and easy. Wire cutters were a bitch)
Old 02-12-2007, 07:55 PM
Bully13's Avatar
Now it should look like this...
Old 02-12-2007, 07:57 PM
Bully13's Avatar
Now pull the arm apart like this...
Old 02-12-2007, 08:02 PM
Bully13's Avatar
Next, cut off the remaining piece of the pin using wire cutters.
Old 02-12-2007, 08:03 PM
Bully13's Avatar
Now it should look like this. Your bolt will be too big for this hole, so get your drill ready...
Old 02-12-2007, 08:05 PM
Bully13's Avatar
Carefully drill the hole to make way for the bolt. This make take a couple of tries as the rubber likes to stick to the bit.
Old 02-12-2007, 08:10 PM
Bully13's Avatar
Now that your hole is drilled, (haha) next put the Carriage bolt through the hole you drilled as seen below. We used this bolt because of the smooth broad surface to further reduce the chance of the tire catching it during rigorous off-road conditions.
Old 02-12-2007, 08:15 PM
Bully13's Avatar
Next run the bolt through the vertical arm as well. It should look like the picture below.
Old 02-12-2007, 08:20 PM
Bully13's Avatar
Using the a crescent wrench attach and tighten the locking nut to the bolt. We used a small monkey wrench to hold the bolt in place during tightening.
Old 02-12-2007, 08:23 PM
Bully13's Avatar
Almost done... It should look like this...
Make sure to repeat steps for the other side.
Old 02-12-2007, 08:24 PM
Bully13's Avatar
Test your air ride to ensure proper operation.
Old 02-12-2007, 08:26 PM
Bully13's Avatar
If you mess up or break the arm, your pretty much screwed so good luck!
Work was performed by H2 Bully and assisted by myself. Pictures were taken by me.
Old 02-12-2007, 08:37 PM
Bully13's Avatar
Don't forget to De-Bling!
Old 02-12-2007, 08:55 PM
drmiles's Avatar
drmiles drmiles is offline
drmiles is off the scale
Great write up,
Note you will only have trouble with the air sensor, if you put wider than 12.5 on stock rims. i.e. 37 x 13.5 x 17 Toyo MT's
Second if you do break the sensor you can manually move each arm into the same position and the air bags will refill. So you can get home on a broken sensor connector rod.
Glad to see everyone going with the bigger tires.
Old 02-12-2007, 09:58 PM
hummer74's Avatar
hummer74 hummer74 is offline
hummer74 is on a distinguished road
yes, very good write up. much better than my ghetto ms paint job. i do need to flip my panhead and bolt like you did, after speaking with doc miles.
so when are you getting the tires? and dont forget to post pics of the tires on your rig!
Formerly Saleen779
Old 02-12-2007, 10:13 PM
H2 BULLY's Avatar
H2 BULLY H2 BULLY is offline
Thanks, I hope to get the tires in a couple weeks
T & A RULES ESCALATOR
Kiss my AXLE
Old 02-13-2007, 04:37 AM
Bully13's Avatar
riiiiiiightttttt.....
