02-19-2007, 06:09 PM
Tie Rod
Broke one of my tie rods on the H3 doing the Odessa trail out in Calico, Ca on Saturday night..It was the Calico clean up event that was gong on out there.... Ended up getting a long bolt to thread back into the lower end, cut of the head of the bolt and bent part overlaped the bolt to the straight piece of the tie road and had someone weld it up for me. It got me off the trail and back home... It's probably stronger now then the original tie rod set-up... They used two Peterbuilt truck batteries as a power source.. You could see the jumper cables jump everytime they started welding... Will post some pictures of the fix when I can...
02-19-2007, 09:02 PM
Re: Tie Rod
WOW.... nice save Chas!
Don't know of any stronger after market tie rods we could get for our 3's do ya? I'd like to get a couple spares for MOAB just in case.
2006 H3 Superior Blue, Adventure + Lux Pkg, Automatic, Sunroof, GPS, Rocker Protection, Black Brush Guard, Roof-mounted off road lamps, Trailer package, Underbody Protection, ROLA Roof Rack, and now Toyo 35's!
02-19-2007, 11:52 PM
Re: Tie Rod
I haven't seen any aftermarket TR ends for the H3's yet. But they don't seem to be as susceptible to breakage as they are on the H2. Just carry some stock spares and you should be fine.
02-20-2007, 12:37 AM
Re: Tie Rod
Thanks Sewie!!! Will Do!
02-20-2007, 07:02 AM
Re: Tie Rod
These guys do a LOT of GM work, I betcha they'd make some up for a group buy! http://www.cognitomotorsports.com/
02-20-2007, 10:15 PM
Re: Tie Rod
What's the GM P/N for the H3 tie rod ?
02-20-2007, 10:18 PM
Re: Tie Rod
Depends. They changed them a while back so there's two different "kits". Have your parts dept look up your VIN and they can give you the correct part numbers.
02-21-2007, 12:48 AM
Re: Tie Rod
And make sure to by the inner and outer (complete assembly).
Some of the first ones ordered (me included) ordered in a "complete assembly" and only got the outer.
02-21-2007, 01:07 AM
Re: Tie Rod
Sorry... I didn't get the part # but my GM dealer said they were $64 & $92.
02-21-2007, 04:45 AM
Re: Tie Rod
Good point. A couple other folks did the same thing which led to a little adventure on Steel Bender when one broke and we had to go back to town to get the right parts.
02-22-2007, 07:17 PM
Re: Tie Rod
 Easy cheese
02-22-2007, 09:48 PM
Re: Tie Rod
how hard is it to change one out on the trail?
02-22-2007, 09:53 PM
Re: Tie Rod
Adam has set the record at 15 minutes
02-23-2007, 01:57 AM
Re: Tie Rod
Well..... I'm making friends with Adam!!!
Hey Adam ole buddy ole pal... what would you like me to bring you in MOAB?
Just name it ole buddy ole pal!!!
Have I sucked up enough?
02-23-2007, 04:22 AM
Re: Tie Rod
Maybe you experienced offroaders could post exactly what you keep in your H3 when your on the trail. As far as trail repair parts, that is....what tools you keep in your H3 etc.
2007 H3 Midnight Blue, Adventure pkg
02-23-2007, 04:44 PM
Re: Tie Rod
Can anybody post a picture of teh tie rod inner and out pieces?
Where do they usually break ? Where the male threaded outer tie rod end meet the female threaded inner piece?
Desert Dan
Jeep TJ Rubicon 2003
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
02-23-2007, 05:13 PM
Re: Tie Rod
02-23-2007, 10:24 PM
Re: Tie Rod
Here's a picture of mine welded back together... Not pretty but it got me home....
02-23-2007, 10:28 PM
Re: Tie Rod
Originally Posted by HBH3
Those are for H2's.
