Old 02-24-2007, 08:25 AM
Default Re: MY LIFTED H3!!!
great lookin' rig man !!
Old 02-24-2007, 09:04 AM
raptorman53's Avatar
Lookn' good Sucks about the CV joint
06 Adv. nuff said
Old 02-24-2007, 06:16 PM
inked's Avatar
inked inked is offline
inked is on a distinguished road
Originally Posted by K9sH3
Or get it dirty as shiate and only wash one side real good and leave the other side alone.
Where in HI are you, I used to work for T&C Surf.
You still located in oahu? Born in Kaimuki, raised in Pearl City, and now living in Ewa Beach. I knew a few people who worked at T&C Surf - Stacey display designer and Marcey graphic designer - not sure where they are now.
That would look cool leaving one side dirty but I think the Hawaii Convention would have a cow if I tracked any dirt on their floors - LOL
- 4X4BOYZ.com - MULTI - 4X4 VEHICLES - GET IT DIRTY
Old 02-24-2007, 06:21 PM
inked's Avatar
Originally Posted by timgco
Looks great!
I was one of the first Rancho lifted H3's. The guys that did the install had some issues with it. A couple of things to check out is the the way the ride height is set up. Make sure they didn;t crank the T bars all the way up with the lift. I had the same rims you have but in all black and had issue with hitting the steering knuckle when aired down at the wrong angle. (17") It seems the ones I have seen with the 18" setup have been fine. I know that with the proper offest wheel and tire setup that H3 has great AP and DP angles. Also check out how far your bumpstops are form touching in the front. That's how I found out the Tbars were cranked all the way. There's nithing wuite like hitting the brakes hard on the highway and the front dips down a foot.
Good luck with it! It looks great BTW!
How does it ride for you at highway speeds?
The T bars are perfect, before the lift I had it jacked up like mad but with the lift it's fine. As for the steering knuckle and bump stops it seems to be fine as well.
My H3 is a daily driver and brought it on the freeway and got it up to 75 and to me it rides better than stock! It hugs the road better, maybe because the wider wheel base because of the wider rims and backspacing - not sure what it is but it does feel good on the freeway.
Old 02-25-2007, 04:49 AM
K9sH3's Avatar
K9sH3 K9sH3 is offline
No, I live in FL. I dealt wiht Graig and his wife and I mostly talked with Stacey and a few others when they would come to the main land for trade shows. They have a factory here in FL, I worked from there, as the Team Mgr for the East coast. I think that was the best job a person could have. Travel, surf, chill etc.. all paid by T&C.
Old 02-25-2007, 06:17 PM
inked's Avatar
Yep whenever you can get paid for doing something you love to do is always AWESOME!
Old 02-26-2007, 12:07 AM
NewHummerGuy's Avatar
i am digging the pool table in garage you got. Sweet man...
Oh ...nice truck too
I'm Gonna crazy you my body
Old 02-27-2007, 08:12 PM
inked's Avatar
I had to get spacers because the control arm was so close to my wheel you couldn't even fit your pinky finger between the wheel and the control arm!! It was about 1/16 away from the wheel. This is due to the backspacing of my wheels - should've got less backspacing...
Not only did the wheel spacer help distance the tire from the control arm but it gave my H3 a wider beefier look. Here's the before and after pics:
Before - no lift, 16 x 8 with 35's, tbars cranked like crazy!
After - lift, 17 x 10 with 35's, 1 1/4 spacer:
Had my friend over at Goodyear install my spacers and torque it for me. No more worrying about the COG (Center of Gravity) due to the lift, the wider wheel base hugs the roads now
Old 02-27-2007, 08:17 PM
HummerHead's Avatar
HummerHead HummerHead is offline
HummerHead is on a distinguished road
Hey I absolutely love your rig...awesome color too! Can you post some closer pics of your Pro Comp rims if you get a chance? Thanks.
Old 02-27-2007, 08:29 PM
inked's Avatar
Here you go!
Old 02-27-2007, 09:01 PM
westhillsat's Avatar
Great looking truck!!!
Old 02-27-2007, 09:41 PM
HummerHead's Avatar
Thanks...again, I love your truck. Keep us updated on how it performs. Enjoy!
Old 02-28-2007, 01:02 AM
ictH3's Avatar
ictH3 ictH3 is offline
ictH3 is on a distinguished road
NICE!
2006 H3 Superior Blue, Adventure + Lux Pkg, Automatic, Sunroof, GPS, Rocker Protection, Black Brush Guard, Roof-mounted off road lamps, Trailer package, Underbody Protection, ROLA Roof Rack, and now Toyo 35's!
Old 02-28-2007, 01:38 AM
That was one of the knocks on this lift from early on. So I'll ask again. What is the backspacing on your wheels?
Old 02-28-2007, 03:50 AM
inked's Avatar
I did find it strange that Rancho recommends 4.5" BS on 16", 17", 18" wheels. 5" BS on 20" & larger wheels. I have 17 x 10 and the 4.5 BS came too close that's why I added the spacers.
Old 02-28-2007, 07:00 AM
Thanks. That's what I figured.
Old 03-03-2007, 07:48 AM
H3slate's Avatar
H3slate H3slate is offline
What is your new ground clearance with the lift? The before and after pics don't really show the difference. How did you like your MT/R's while you had them? They sure looked great!
Old 03-03-2007, 09:12 AM
Urban Ops's Avatar
Urban Ops Urban Ops is offline
Urban Ops is on a distinguished road
Are those wheels the new 7189?
Master Sgt. Art Lilley 1972-2007: The perfect example of what a man should be.
A brave man and a fellow four wheeler dies for us
My son and I will both miss you greatly Art. Thanks for everything!
Old 03-05-2007, 06:19 AM
inked's Avatar
I still have them and are selling them for $850 rims and all!!
As for ground clearance it didn't change, but once I add 37's it should clear about 2 more inches...but still thinking about it.
Old 03-05-2007, 06:20 AM
inked's Avatar
Yes it is the new 7189 Series
