Old 02-26-2007, 08:36 AM
KrazyMedicRN's Avatar
KrazyMedicRN KrazyMedicRN is offline
KrazyMedicRN is on a distinguished road
Lightbulb Train Horn Mounting in SUT
I have seen how other people have posted their horns before but I am looking for suggestions on a possible bracket design that will hold the compressor and tank so they don't have to be mounted directly to the wheel well.... below are pictures of the items I plan on using as well as some previous pictures from other installs.
any info or suggestions would be appreciated.
These are the horns I am going with
I am adding triple solenoids and will be running 2 3/8" Braided Lines from the tank thru the Drain hole... one will power the horns and the other is planned for running a second line with a quick connect for airing up and using a ratchet if works
I am going with a 3 gallon tank
and a Air Zenith Compressor with a 175 psi pressure valve on the tank
Thanks in Advance
Rich
Picture of my 2005 H2 YELLOW SUT
http://www.myspace.com/krazymedicrn
Old 02-27-2007, 06:26 AM
Default Re: Train Horn Mounting in SUT
Well it looks like you've researched it from this site.
Where would you like to put the air tank? It's hard to hide big things like that 3 gallon tank and compressor.
Is your question for a bracket design to mount the tank and compressor on, and then fit that over the wheel well?
