Old 11-30-2004, 01:56 PM
NK NK is offline
NK is off the scale
For those how have the H-cam
Am trying to install my H-cam to my kenwood 715, I did every thing in the instillation manual and rechecked again and again
All I get is black screen with some static – please help
NK NK is offline
NK is off the scale
NK NK is offline
NK is off the scale
Old 11-30-2004, 06:13 PM
akakustom akakustom is offline
akakustom is off the scale
there probably is a trigger wire that you didn't hook up, this wire is supposed to get hooked up to the e-brake but most people connect it to ground so you can see video while you're moving<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by NK:
All I get is black screen with some static – please help <HR></BLOCKQUOTE>
Old 12-01-2004, 05:40 AM
NK NK is offline
NK is off the scale
philD
No didn’t buy the monitor, cam only. But I have a visualagic headrests monitors, I tried those two get the same results. And I believe I have power since there is a static line, I pulled the fuse and the static was gone. But I’ll check the power line again.
Akakustom
This wire goes to accessory wire it’s hooked up and I can watch DVD while am driving, but there is another wire coming from the cam that go to the reveres gear, I hooked this one to power. Am not sure if this one should go to accessory line???
I would try to do it but I didn’t find accessory line in the hitch plug..
Old 12-03-2004, 01:10 PM
NK NK is offline
NK is off the scale
Relay kit installed and working 12.8 v, power going to camera checked 12.8 v. all connectors are checked..
I wander if I can check the signal coming from the RCA wire going to the video input??
Old 12-07-2004, 05:57 AM
NK NK is offline
NK is off the scale
This is the reply received from TrailDuty.
A complete H-CAM system will ship today and be with you later this week. Please try the new system (you may just want to connect it before installing anything) and see if it solves the problem. Please return all that you do not use to us and let us know the cost of shipping and we will reimburse you (or you can use our DHL account # - xxxxxxxxx
Apologies for the inconvenience.
Phil.
Before that he offers to send me a HitchCAM monitor just to test my camera.
Great support AAA+
Old 01-11-2005, 01:35 PM
NK NK is offline
NK is off the scale
the new cam is up and running. look good and works greet.
thanks guys for your help.
