  #41
Old 02-17-2007, 01:34 AM
drmiles's Avatar
drmiles drmiles is offline
drmiles is off the scale
Default Re: Air ride sensor mod made easy!
I guess you could bend the arm in and up which would cause the computer to raise the rear.
Wow rear air, lift kit, one propane torch and a little bending
Old 02-20-2007, 01:41 AM
rusty rusty is offline
rusty is off the scale
well thanks for the response dr, i guess it will take a couple of months for me to wear down my 12.50s and try it, but im excited already
Old 02-28-2007, 01:03 AM
Boston Hummer Boston Hummer is offline
Boston Hummer is on a distinguished road
Dose anyone know if you can bypass the airbags and install coil springs?
Old 02-28-2007, 07:54 AM
So all ya need is the 2 springs and the 4 isolator pads? Then take out the air compressor, anyone know how to trip the sensor so the idots lights don't come on?
Old 03-01-2007, 01:44 AM
hummer74's Avatar
hummer74 hummer74 is offline
hummer74 is on a distinguished road
why not leave the compressor in so you have onboard air?
Formerly Saleen779
Old 05-30-2007, 07:35 PM
Don't your nuts rub -------(the frame) after you do this?
Old 06-29-2007, 03:03 AM
btt.
How far do you tighten the bolt/ nut? Do you snug it up or leave it loose?
Does anyone have a connection to have this assembly made out of aluminum?
Old 07-03-2007, 10:35 PM
I tightened mine snugly, until it just started to restrict free movement, but I think you could leave it loose if you use a nylon nut.
Mine seems to work ok, but the end of the bolt rubbed the frame until I hogged out the rear mounting bracket hole and moved the arm away from the frame.
