Old 02-27-2007, 11:55 PM
NYSUT's Avatar
NYSUT NYSUT is offline
NYSUT is on a distinguished road
Default mirror covers
in the process of blacking out my sut.
almost done.
about to have my center caps sprayed w/ clear and extra powder from my p/c rims.
anyway, wanted to have my mirror caps done at the same time.
any of u guys who have either had urs painted or rattlecaned them have any info/advice on taking them off w/o breaking any tabs, etc.
as usual thanks in advance,
bill
Old 03-01-2007, 04:10 PM
NYSUT's Avatar
Default Re: mirror covers
just so u guys know:
after searching forum and finding out the chrome parts come off from the inside i took them off last night.
really not that hard at all:
1)pull out/off mirror glass
2)remove 4 bolts holding mirror together
3)seperate mirror
4)pop chrome piece out of mirror half
good luck if u try,
bill
p.s. p/c rims and gas cap are on / having caps, mirror covers painted
black it out in progress (aka murdered out)
Old 03-01-2007, 06:26 PM
Cool, I finally replaced a good portion of color and chrome on my H2 with black parts yesterday. Just need to do my rims, gas cap and mirror inserts as well.
Old 03-01-2007, 06:34 PM
3)seperate mirror
good luck if u try,
bill
I hope you are having your mirror covers plastic coated. That duplicolor tends to come off on the corners here and there. Since th ebugs gt smashed all over them, you cannot scrub them too hard or take a preasure washer to them. That plastic coat stuff will hold up better than paint ot the duplicolor.
Old 03-01-2007, 07:07 PM
what is the plastic coat stuff called.? can you get it at pep boys?
Old 03-01-2007, 09:03 PM
NYSUT's Avatar
figured i try paint at first by a local shop (multi coats plus mult clear), then adjust from there
real good point though
just dropped off 8 wheel caps (knowing some clown is going to steal one eventually), mirror caps, and the grey license plate/rear tire cap piece
this will make my sut all black except for the spare that needs to be p/c
and may tint front side windows/back window dark
i'll post pics soon
also noticed your h2 logos, were they painted?
thanks,
bill
Old 03-02-2007, 12:46 AM
i'll post pics soon
thanks,
bill
The H2 badges are duplicolor also. FWIW, when I had my stock rims PC'd on my SUT, I had the center caps plasticoated and they held up very well.
Old 03-02-2007, 04:18 PM
NYSUT's Avatar
thanks timgo (always in the know)
figured caps are pretty cheap if they don't survive i'll try your suggestions
i'm hoping paint shop is done today, if not monday
i'll post some pics then
truck has no chrome (not even hood latches or door handles)
changed to black grille
p/c wheels and chrome gm hummer gas cap
sent out caps, mirror covers, and license plate holder grey insert
maybe tint windows next? and badges?
thanks again,
bill
my H2 is a hybrid...it runs on gas and then switches to ground up treehuggers
Old 03-02-2007, 05:55 PM
Don't forget to smoke or clear the marker, turn signal, cab and tail lights. Must remove all color!
