03-20-2006, 09:08 PM
Hey guys, im havin trouble installing the superchip programmer. The programmer wont get past the initializing part and then it states that theres a code 038 error. anyone know whats going on with it? thanks!
03 White H2 with Banks exhaust, Volant intake, 4\" Rancho lift, 18\" black Rockstars, 37\" ProComp Xterrains, Roof Rack and lights and a lot of turning heads!
03-20-2006, 10:10 PM
Not trying to be a wise guy or anything but are you sure you pulled the right fuse? Did it say "info 15 amp"?
03-20-2006, 10:21 PM
lol, I hear ya. Actually, there wasnt even a fuse in there.
03-21-2006, 12:05 AM
There are actually 3 or 4 fuses that need to be pulled. Anything to do with onsar, radio or amp needs to be pulled.
03-21-2006, 12:09 AM
I thought that was only if they were aftermarket  .
03-21-2006, 01:33 AM
No, oem databus communications. Actually, the programming can fail if your onstar takes an update or tries to communicate with the radio. Directly from my superchips manual, it says to remove the following fuses: from the driver side fuse panel, remove SEO ACCY; from the exterior fuse panel, remove SEO B1, SEO IGN, INFO, SEO B2, RADIO, and RADIO AMP. I had to try mine 3 or 4 times before it worked properly.
03-21-2006, 05:51 AM
It might be your battery.. i remember reading a GM techlink that you need to have your battery fully charged and that they have their mechanics connect a battery charger whenever they reprogram or flash the computer... i was trying to post a link but i can't get into gmtechlink.com
03-21-2006, 06:08 AM
03-21-2006, 10:54 AM
yall rock, thanks for the info! ill give it a try today and see how it goes. the info15 was out and it still have me the error code so ill try the other 30 fuses later! take it easy boys!
