Old 03-09-2007, 06:53 PM
rrboy rrboy is offline
rrboy is off the scale
Default for those looking for toyo mt's
I was surfin the web last night and found a great deal on toyo mt's. I have no idea if this guy is for real, but if it is..thats a good price for the
LWM Transportation Enhancement
Contact the seller instantly
Toyo Open Country MT Tires
Size35x12.50x17Load RangeLoad Range E
Max Load 3640
Height and Width34.8"x13.2"DescriptionAll Around Traction
- Aggressive, attack tread design with hook-shaped blocks
- Scalloped shoulder blocks
- Tread block stabilizer
- Deep siping in the tread blocks
- Open shoulder design
Styling
- Over-the-shoulder tread
- Black outline serrated lettering
- Rim protector in lower sidewall
Excellent Handling On/Off Road
- DSOC II? Technology
- High turn-up, 3-ply casing
- Two wide steel belts
- Two spiral wound nylon cap plies
- High bead filler
Excellent Grip In All Elements
- Cap/base construction
- Tread block stabilizers
- Open, scalloped shoulder blocks
Smooth, Stable Ride
- Computer-optimized tread design
- Advanced production technology for unheard of levels of uniformity
- Tread elements shaped and staggered for reduced noise
- 3-ply polyester casing
- Single strand, jointless bead wire construction
Durability and Long Life
- High turn-up, 3-ply polyester casing
- Bruise and abraision resistant sidewall compound
They are brand new FIRST LINE tires, in brand new condition, with zero miles on them. ;
Old 03-09-2007, 10:27 PM
dochummer's Avatar
Default Re: for those looking for toyo mt's
You can get them cheaper here...
http://www.ec-securehost.com/OnlineT...untrry_MT.html
Shipping to Washington isn't that bad...
'03 H2
Old 03-10-2007, 03:27 PM
hummer74's Avatar
hummer74 hummer74 is offline
hummer74 is on a distinguished road
www.tiredeals4less.com is even cheaper. but im not sure if they carry the 35"x12.5x17 i got discount tire to match the price tiredeals4less had on my 37x13.5x17 too!
Formerly Saleen779
Old 03-10-2007, 05:51 PM
dochummer's Avatar
The shipping is what kills the deal at tiredeals4less for me...
'03 H2
Old 03-11-2007, 12:54 AM
hummer74's Avatar
i though $229 shipping for five 37x13.5x17 tires from illinois to texas was good?
Formerly Saleen779
Old 03-11-2007, 01:35 AM
dochummer's Avatar
$1108+ $64.99 shipping for me...
'03 H2
Old 03-11-2007, 01:49 AM
from where and for what size? thanks
Old 03-11-2007, 05:59 AM
dochummer's Avatar
I was looking at the 37" toyo m/t's.
'03 H2
Old 03-11-2007, 09:22 PM
Gunzz's Avatar
Gunzz Gunzz is offline
Gunzz is off the scale
Will these tires ( 35 inch) fit on the stock rims ? Also will they fit under the stock truck without rubbing ? Thanks. Looking into all my options.
Old 03-11-2007, 09:39 PM
dochummer's Avatar
The 35" toyo's will fit stock rims with no problem. The 37's will fit with minor rubbing, and a couple of mods to protect the sensor..
'03 H2
