  #181
Old 03-12-2007, 08:40 AM
MarK M's Avatar
MarK M MarK M is offline
Default Re: Rear Brake/Axle Groan...
wow, heard this exact noise you all mention this weekend. i slammed on my brakes because some prick cutting me off and I heard the noise.
was going to take my H3 in to have them look at it, but thought i'd search and see if its a common issue on the boards. seems that a lot of you guys get this noise. is it really normal? i'm afraid of taking my H3 in and they tell me the same thing, in that its normal.
i dont recall my H3 doing this before and i've slammed on the brakes a few times before. do most of you just live with it?
Old 03-12-2007, 12:34 PM
NO ! It is not normal. The lit talks about colour, mpg, torque, load, accessories, etc, NOTHING ABOUT BRAKE SQUEAL
Old 03-14-2007, 03:09 AM
Hmmm2's Avatar
Hmmm2 Hmmm2 is offline
was going to take my H3 in to have them look at it, but thought I 'd search and see if its a common issue on the boards. seems that a lot of you guys get this noise. is it really normal? i'm afraid of taking my H3 in and they tell me the same thing, in that its normal.
No, it's not normal. One of us had a problem with the tranasfer case (f5fstop) and a few of us with the brake pads. Fourfourto and I had the rear pads chamfered and it took care of the problem. Good luck! Let us know what happens.
2008 H2 Graystone Metallic
2006 H3 Black (sold)
previously known as Hmmm3
Old 03-14-2007, 03:39 AM
fourfourto's Avatar
Mark make sure they put disk brake lube on the shims also.
Hmmm Im still quiet
4000 miles+
The dealer did use disk brake quiet spray and you could see were it was rubbing or vibrating,hopefully the lube last longer.
I think at the next tire rotation I will relube even if noise doesn't come back by then..
Old 03-14-2007, 06:13 AM
MarK M's Avatar
cool, thanks guys!
I'll take the H3 in to have them look at it.
Old 03-14-2007, 07:21 AM
Hmmm2's Avatar
Hmmm Im still quiet
4000 miles+
Sounds good to me! I've been quiet, too!
