Old 03-13-2007, 10:54 PM
FJD FJD is offline
FJD is an unknown quantity at this point
Default How do you keep the back gate open??
Hey All,
I do a lot of stuff outdoors that I seem to be standing behind my H3 an awful lot with the gate open. There are times that I can't find level ground to park it on and if the truck is leaning to the right, I can't keep the back gate open. Have any of you guys figured out a way to keep it open?? Anyone devise something to cram into the hinge or against the door jamb to keep it from swinging closed?? Since the gate is rather heavy and if you're on a pretty good slope, you really need something substantial to keep it open.
Any suggestions???
Any ideas would help.
TIA...
Old 03-13-2007, 11:38 PM
Viet Nam Vette's Avatar
Default Re: How do you keep the back gate open??
This might be the wrong answer but... my 07 has a Gas strut that holds the door open and also adds an assist when I first open it. Not sure if yours is an 07 or if in fact the 06's had it but if not maybe you could add one.
If you do have the strut...then my answer is
Old 03-14-2007, 12:19 AM
Desert Dan's Avatar
Try to park it leaning to the left if you can?
I have thought of using a piece of wood to prop it open. I think Land Rover Discoverys have some kind of a latch that holds the door open. I have aslo seen some after market ones for Jeep Wrangler doors
Also on steep hill that rear door and tire can be pretty heavy
Desert Dan
Jeep TJ Rubicon 2003
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
Old 03-14-2007, 01:06 AM
3Hummer's Avatar
3Hummer 3Hummer is offline
My trunk usually stays open if i put it open, but i dont think ive parked on a hill as steep as the one your talking about. But my suggestion was get something to hold it open like a stick or something, like some cars have to hold open there hoods.
2017 VW Jetta S
2012 Cessna 182T Skylane
/''T''|[___|___]
[---T--L -OlllllllO-]
()_)"""()_)/"**"\)_)
Old 03-14-2007, 08:25 AM
H3PAC's Avatar
H3PAC H3PAC is offline
Try this, except put it on the other side.
Old 03-14-2007, 09:42 AM
RuggedH2's Avatar
RuggedH2 RuggedH2 is offline
Attachment 37253
Wow! Damn, that guy is a total asshat. When those 2x4's slip or break, he can wear his own ass as a hat.
Old 03-14-2007, 11:24 AM
Crash ?'s Avatar
Crash ? Crash ? is offline
Welcome to the wonderful world of Bungee Cords...
Strap a Bungee from the spare wheel to the rear drivers side wheel...
Rob
Old 03-14-2007, 12:31 PM
Maybe in future years HUMMER will put the spare on its own swing and change the back access to a lift & drop or a total lift...
RYD
Old 03-14-2007, 03:52 PM
FJD FJD is offline
Thanks for the thoughts guys. I tried all of these and was looking for something a little better. I have an expandable tent pole with a rubber end on it that I use to prop the gate open with. I tried the bungees and the gate is too heavy, I think rope might be better. I was hoping someone had designed something that could be stuck in the frame between the door and the jamb to keep it open. Oh well, I'll keep trying until I find something that works!!
Thanks again.......
Old 03-14-2007, 04:15 PM
Attachment 37253
Hey he's got the wheel blocked one way. Somebody get me his name and address because I'm getting an insurance policy on him AND I smell payday . the Rebel
H2 REBEL lennyrebel
Old 03-14-2007, 04:34 PM
tomp's Avatar
tomp tomp is offline
Cut a piece of angle iron the same length as the small tube on the doors' gas strut. After you open the door, slap the piece of angle iron on the small tube: problem solved
Old 03-14-2007, 05:00 PM
FJD FJD is offline
I thought of this but I'm not too sure whether the housing on the strut can take the pressure of something jammed in there with the weight of the gate against it. I thought of clamping the strut once it is open but again, not too sure it can handle the weight of the gate.
Old 03-14-2007, 05:54 PM
remove door
Old 03-14-2007, 06:47 PM
Crash ?'s Avatar
You mean like a block of wood..???
Rob
Old 03-14-2007, 09:15 PM
Are you planning on driving while the rear gate is open ?
Old 03-14-2007, 09:47 PM
FJD FJD is offline
Yeah, I guess a block of wood would do.
Nope, no driving with the gate open RYD...
Old 03-14-2007, 10:11 PM
Thats good, because if you did we would help pay for the lobotomy...
Old 03-14-2007, 11:49 PM
Demo's Avatar
Demo Demo is offline
take a look at a Land Rover Discovery Rear door. They designed it so it stays open. I have been thinking about getting a used whathcamacallit from a Disco and retrofitting it to my H3 becuase I almost got chopped in half by my rear door the first time I went camping.
Dealer said deal with it.
Old 03-20-2007, 12:38 PM
Crash ?'s Avatar
I haven't looked under the door to check out the clearance issues, but maybe mount a second strut under there.. Or maybe just find one that's rated for a higher "push"... Are they rated..???
Rob
Old 03-21-2007, 10:18 PM
lance-n's Avatar
lance-n lance-n is offline
lance-n is off the scale
The strut on mine works fine, regardless of the angle. Now, I have never laid the H3 on its right side and see if the door will stay open!
In fact I really like the gas strut, since my wife has no trouble opening or closing the door. Closing the tail gate on our Bronco is pretty tough (and heavy) for petite people! I went to the beach last Saturday with a buddy who has an fj (beat to **** already by the way) and I noticed that they have the same configuration for the rear door except their strut has a little snap that allows you lock the extended strut into place so it won't close on you. I also noticed that if you do not lock it into place, even on level ground, that darn door will come back at you. Their may be a way to modify the H3 strut to lock in a way similiar to this. It may be as simple as making a notch in the extended strut and using a hose clamp or some other item to hold it extended.
I don't like leaving the doors open when I am camping anyway, all the bugs come inside and f@#K up my leather!!!
Regardless, park it on level ground when you camp!
White, Adventure, Chrome Billets, Black Leather
1995 White mint OJ mobile (full size Ford Bronco) - sold
2007 Silver Nissan Armada - wifemobile
2005 42' Tiara Sportfisher - Tournament Rigged and 40 knots!
