Old 03-21-2007, 05:52 PM
greg938 greg938 is offline
greg938 is on a distinguished road
Default OEM Steps Bolts
I need OEM Tubular Step Bolts...does anyone know type/size? Over $100 from the dealer! Thanks!
Greg
Old 03-21-2007, 06:45 PM
Default Re: OEM Steps Bolts
your kidding bro, so the steps make it ok? Let me ask around. should be just a few bucks at a pep boys or checker.
Old 03-21-2007, 08:09 PM
They should be here Friday...can't wait! The GM Dealer here said about $100, the Hummer Dealer about 2 hours away said they cannot get them unless I order the steps. I can figure out what they are...just thought there may be some info out there on them. Are the nuts permanently mounted on the frame, so I just need bolts? Thanks!
Greg
Old 03-21-2007, 08:39 PM
SR1355's Avatar
SR1355 SR1355 is offline
If your talking about tubular side steps they should be 10mmX25mmX1.5T. If I remember correctly from installing rock rails. The rock rails used the same location fasteners as the OEM tubular side steps.
Paul M
SR1355
Old 03-22-2007, 12:17 PM
RuggedH2's Avatar
RuggedH2 RuggedH2 is offline
You can buy the same bolts from Chevrolet cheaper.
The bolts that came with my Rocky Road rails were the wrong ones. The Chevy dealer is much closer than the Hummer dealer so I went there first, problem solved for half the price - for the same bolts.
Might just be the individual dealer markup. The Hummer dealership here charges top-dollar on everything.
Old 03-22-2007, 12:52 PM
CrisB's Avatar
CrisB CrisB is offline
Greg
$100????? Are you joking? Hardware store will only set you back about $8
Old 03-22-2007, 02:53 PM
I am definately going to my local True Value hardware store. Thanks for the info.
Greg
Old 03-22-2007, 10:44 PM
evldave's Avatar
evldave evldave is offline
evldave is off the scale
Greg
Make sure you get at least Grade 5 bolts...
