Old 03-26-2007, 12:31 AM
bparker's Avatar
bparker bparker is offline
Default Re: What's a good alternative to Tile in a Bathroom Floor?
Yea, I agree, the smaller the tiles the less attective. The larger the tile the larger the room appears to be. 6" tiles are too small. I myself like 12" and above.
But this is only 1 style of many many tp choose from. I used 12" slate look in my last house and it was perfect.
Have a look at that link for more.
Originally Posted by HummBebe
looks like 10 inch squares, but it's on a roll, correct? ( like linoleum?) If they had that in 20 inch, I'd be lookin at it for sure.
Thanks BP
http://www.tahoeforum.com
http://www.motoforum.com
Old 03-26-2007, 01:21 AM
evldave's Avatar
evldave evldave is offline
evldave is off the scale
Originally Posted by bparker
There are some really good "peel and stick" slate looking tiles out now that are NOT laminants (printed pattern with a clear gloss laminate top) - they are made by solid melted stock and are tough as nails. They stay room tempreture and are easy to "fix" in the event you have a water problem. Most people can not tell that it is fake until you tell them. They even have grout lines and everything.
They are a nice, affordable easy to maintain floor.
Peel & stick = not a good idea in a bathroom. No matter how much you pay for high-end stuff, the 'sticky' can't handle the humidity changes in a bathroom and you'll have problems. I'd suggest travertine (less expensive) or 12x12 or 16x16 slate tile (more expensive).
Actually, I wouldn't recommend tile at all unless you have heated floors (that's my personal preference) - I hate having cold floors getting out of a warm shower and no matter much you try and heat the room, the tiles will always feel cold on your feet.
I think a good alternative is thick linoleum as mentioned earlier. It's softer (nice to walk on) will be warmer on your feet, and easy to clean (no grout, single sheet). It's also super-simple to install and easy to repair. If you want the tile look, get a thick linoleum with the square tile pattern (and those are even easier to repair).
Old 03-26-2007, 01:45 AM
Use a bathmat
Old 03-26-2007, 02:31 AM
bparker's Avatar
Actually, the stuff I am talking about was specifically designed for bathrooms and kitchens. High traffice areas. The solid stock i am talking about could even handle commercial use. Its about as strong as Azrock tile which is what you walk on in Wall-Mart.. and guess what? Thats peel and stick too
Old 03-26-2007, 06:48 AM
Alright......I think I'm now convinced to stay with tile or slate. I'm going to work with my electrician to see if he can help out with those warming grids that you mount below the tile to keep it warm.
I was hoping there was some miracle material out there that I hadden't seen. Guess not. Thanks guys.
Old 03-26-2007, 06:49 AM
Old 03-27-2007, 07:20 PM
BKLYNH2's Avatar
BKLYNH2 BKLYNH2 is offline
I would go for real slate (over the aforementioned peel and stick) no matter what its better quality. Slate can come in a variety of finishes that are both pleasant to the feet and aesthetically appealing, and not slippery either. It will naturally feel warmer than a tile floor, however you can also get a small heater which fits under the toe kick space of a vanity which will blow hot air low to the floor, they work well, are not super expensive, and you'll never see it. If you go with slate don't go with something that has a lot of variance in the surface as all the nooks and crannies will collect water deposits that will look like stains over time, especially if the water is hard.
Old 03-27-2007, 07:39 PM
evldave's Avatar
That's good info, didn't know about that stuff. Sounds like solid flooring material.
Our work uses 18x18 carpet tiles w/molded rubber bottoms. They aren't peel&stick, they just fit in place and never come up. If something stains them or they get cut, just stick a blade under a corner and lift up and replace that carpet square. You can't see the seems at all! They were replacing a bunch at work and I picked up a couple cases - they worked great in the garage, just laid them out on the floor. Soaked up all kinds of abuse, then after awhile I just sprayed them out let them dry and put them back down. Best garage flooring I've ever used...
Old 03-27-2007, 08:08 PM
Good Info, P! I just heard about those toe-kick heaters yesterday. I might investigate that.
Old 03-28-2007, 01:39 AM
bparker's Avatar
I thought you were asking for "affordable" floors
I also have slate throughout my house in all the hallways, kitchen and carpet only in the bedrooms and that stuf in no way shape or form is "affordable" haha
But I must admit, its one of the finest besides granite.
Granite sure is slippery though with wet feet.
Old 03-28-2007, 01:53 AM
Our HVAC has an outlet built into the toe-kick of the kitchen cabinet right under the sink. Good for keeping CP's toes toasty warm on the cold winter nights...
while she's doing the dishes....
Old 03-28-2007, 02:04 AM
bparker's Avatar
Speak up I didnt catch that...
Wait let me turn it up..
There we go.... now I will wait for the echo sound of a slap hehehe
Old 03-28-2007, 02:09 AM
