Old 03-28-2007, 04:09 AM
tomp's Avatar
tomp tomp is offline
Default Is this button suppose to light up?
Is the button to activate the rear locker, suppose to light up like the other 4WD drive option buttons?
Old 03-28-2007, 04:57 AM
Vettster Vettster is offline
Default Re: Is this button suppose to light up?
I had to run out and check on my 06.
The button lights up with the dash lights. When activated, a little orange
dot lights up near the bottom left of the button.
Hope this helps.
Old 03-28-2007, 03:17 PM
tomp's Avatar
It does help, thanks! My LED lights up when activated, but the button itself does not light up when lights are on like the ones below it. Looks like a warranty issue.
Old 03-28-2007, 04:24 PM
Old 03-31-2007, 03:48 AM
orlasttoy's Avatar
orlasttoy orlasttoy is offline
orlasttoy is off the scale
just noticed i lost a few more backlights tonite...the 3 fan control buttons to the left (on an '03)
do these whole buttons need to be replaced (like the steering wheel buttons?)
or is there an easy bulb replacement?
Old 04-10-2007, 04:05 PM
tomp's Avatar
Vettster, are you sure about yours lighting up with the dash lights? We checked most of the H2s at the dealer, and none of them light up. Only the LED lights up when activated.
Can anyone else confirm there's lights up when other dash lights are activated? (Not referring to the LED)
Hope this helps.
Old 04-10-2007, 08:24 PM
tomp's Avatar
I caught your earlier note Phil, thanks
