Old 03-24-2007, 10:45 PM
Default Can anyone 'splain how to measure "Arch"??
I need to measure the arch on my springs for my add-a-leaf,.
I looked it up, it shows what the measurement is, but I hope I do not have to take off my leafs to obtain the measurement.
Do I?
Old 03-24-2007, 11:22 PM
Default Re: Can anyone 'splain how to measure "Arch"??
Did you forget HS Geometry. Get out your protractor and compass and measure the angle. Then plot it. You should be close to factory spec.
Old 03-25-2007, 12:29 AM
Directed angle measure(theta) times radius= arch length
Old 03-25-2007, 01:15 AM
Thank you so much, I know how to arrive at the measurement, can I do it crawling under my truck? Or do I have to remove it and measure laying on the ground?
Old 03-25-2007, 11:07 AM
HB,
Check with manufacturer of product. Would make sense to not have to remove it first. However reality and Murphy's law state other factors. Like measure 2x cut once!
Old 03-26-2007, 05:56 AM
Old 03-26-2007, 10:33 PM
Can someone measure this arch for me?
Old 03-26-2007, 11:21 PM
Sure, I probably could.
Old 03-26-2007, 11:51 PM
Desert Dan's Avatar
The spring place should know what the stock specs (width, length, thickness, spring rate and center pin location) are. Then they can make the new spring add a leaf or a whole spring pack. You may nee longer U-bolts too.
Are they going to do the install?
It is allways Springtime Here!
Desert Dan
Jeep TJ Rubicon 2003
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
Old 03-27-2007, 12:16 AM
You guys are mean......I'm telling.
Old 03-27-2007, 04:33 PM
stagger_lee's Avatar
Im pretty sure you measure at full droop too, so jack up the rear end first.
White Collar Hippie
'06 Luxury Adventure
'99 Toyota 4runner 4x4
'71 FJ40
Old 03-27-2007, 05:17 PM
Thank you!!!!!!
Old 03-27-2007, 06:14 PM
You're talking about the truck right?
Old 03-27-2007, 06:23 PM
Yeah buddy!
White Collar Hippie
'71 FJ40
Old 03-27-2007, 06:29 PM
ree's Avatar
ree ree is offline
What needs to be measured? Can't you do it with a flexible tape while lying underneath the truck?
'03 pewter base H2
Old 03-27-2007, 06:47 PM
Unforunately you have to do the math above to insure proper spring rate. You could have 62" leafs on 2 different rigs, but the distance between the hangers could be different. Effects sag, stiffness, recoil, and shock length and travel would also be effected etc. They take the measurements into consideration along with added rear end weight and customer preferences, if getting a custom job. DEAVER baby!
She is just doing an add a leaf, but they would still need the right measurements.
White Collar Hippie
'71 FJ40
Old 03-27-2007, 06:57 PM
Old 03-28-2007, 07:31 AM
Old 03-28-2007, 02:11 PM
ree's Avatar
ree ree is offline
I wasn't advocating doing no math. I was really questioning if you had to remove it from the vehicle. I assume you measure the length along the spring from mount to mount (with a cloth tape) and straight line distance between the mounts....and then do some math. Do you have to do it with the load of the truck on it, or with the spring under no load?
'03 pewter base H2
Old 03-28-2007, 04:12 PM
Sorry, yeah thats what ment in previous post when I said to measure at full droop, or with the load off of the springs.
White Collar Hippie
'71 FJ40
