Old 03-28-2007, 04:33 PM
Desert Dan's Avatar
Default Re: Can anyone 'splain how to measure "Arch"??
Generally it would be better to build a whole new spring pack made up multiple leaves than just adding an add-a leaf.
The ride would be better and the spring rate more progressive
You could also add a second stock leaf under the main leaf to give a little more load capacity. Ive done that on Jeeps and Toyotas.
One down side about springs under the axles is that the more leaves you have, the lower the u bolt spring plate and skid are as far as ground clearance
Desert Dan
Jeep TJ Rubicon 2003
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
Old 03-29-2007, 02:05 AM
Originally Posted by Sewie
Don't go away mad......
Old 03-29-2007, 05:24 AM
CrisB's Avatar
CrisB CrisB is offline
You're talking about the truck right?
http://www.h3adventures.com/temp/cd.htm
SEWIE, YOUR COUNTDOWN CLOCK RULES!!!
Old 03-29-2007, 06:41 AM
