Old 03-30-2007, 06:10 AM
Hunner's Avatar
Hunner Hunner is offline
Default Re: Hunner's Skids Install made simple
Originally Posted by SR1355
Have the rear plates in for powder coat so I'll be installing in a few days. What is the correct spec for the u-bolt torq? Info would much appreciated.
We looked this up for an 06 and 07 hit the print button on the 07 but they are the same.
Old 03-30-2007, 12:40 PM
deserth3's Avatar
deserth3 deserth3 is offline
I think I remember someone here had Amstar ones put on by a dealer and was told they had to replace the U bolts too be cause they stretch when installed.
Something to look into.
Old 03-30-2007, 02:56 PM
Hunner's Avatar
Whatever the individual decides. If that gives someone piece of mind by all means do so. They probably would if ask not recommend you go offroad and bash about over rocks and run the vehicle thru gritty mud and sand as well. I believe GM built the H3. I have noticed Amstars web site is still back under construction. Local spring shops are the best source for ubolts replacement. I had about 3000 miles on mine when I installed the skids. I did not replace mine. The springs have not fallen off.
Old 03-30-2007, 11:09 PM
SR1355's Avatar
SR1355 SR1355 is offline
Thanks for info Hunner... I torqed them to 60 the other night so a littel over spec.
Paul M
SR1355
Old 04-01-2007, 06:10 PM
Demo's Avatar
Demo Demo is offline
Hey guys, thanks for the write up Tim. Going to put them on today, finally got my H3 back. I printed out you write up and I should be a big help.
Old 04-02-2007, 02:49 PM
Crash ?'s Avatar
Crash ? Crash ? is offline
I got to see them in action on Hunner's truck Saturday.. I was following him on a trail at Superlift and he nailed a big rock in the middle of the trail.. Left rear tire lifted up and the skid rolled right over the rock.. After seeing that I had enough sense to stop, walk up and roll the rock over to the side before following on..
Of course by then he'd disappered around another corner and we didn't have a clue which trail he'd headed down.. We decided it prolly wasn't the one rated 5...
Rob
