Old 03-31-2007, 03:58 AM
Default Extended Shackles
Here are my new SamCo Fab shackles !!!
I'm putting them on tonight and tomorow, pics to follow
Old 03-31-2007, 03:59 AM
Default Re: Extended Shackles
Old 03-31-2007, 04:25 AM
CrisB's Avatar
CrisB CrisB is offline
How much do they add to your rear height, Bebe? Why are you adding them again?...to keep up with the added front height with new HD Tbars?
Looks like great fab work, can't go wrong with that!
Old 03-31-2007, 06:24 AM
That's one reason, but mostly to add height to the rear to compensate for the weight I have added.
Along with helper springs it will add height and stability to the truck.
Here is cestwicks truck after he added his extended shackles....
Old 03-31-2007, 02:37 PM
H2 BULLY's Avatar
H2 BULLY H2 BULLY is offline
Cool!! Moab will be a great place to test all your new goodies
T & A RULES ESCALATOR
Kiss my AXLE
Old 04-01-2007, 01:42 AM
CrisB's Avatar
Thanks, that makes sense...but the pic's kinda deceiving, isn't it? On a twist, I can get that rear clearance. Got one on flat ground?
Without the new (or highly cranked) T-bars, that'll lift the back up the air like a cat in heat.
Old 04-01-2007, 04:43 AM
I hope not, it's only supposed to add an inch. We will see in the morning
Old 04-01-2007, 04:45 AM
Here's one on flat ground, and with 35's.
http://www.elcovaforums.com/forums/s...24&postcount=3
Old 04-01-2007, 05:00 PM
WOW! That makes the 35's look like 33's back there. SO that little bit should help a bit IMO. BEBE, I thought this thread was something complete different!!!!!!!!!
Old 04-01-2007, 11:48 PM
Stevenblanca Stevenblanca is offline
Stevenblanca is on a distinguished road
Cool Re: Extended Shackles
Nice pieces. I've just send an email to Samco to see if I can order the same parts. It is not advertised on their website.
Lets wait and see.
Victory Red 2006 H3 Luxury, Automatic, OEM steps, Sunroof. MODS: Torsion bars 4X, Front Bilstein shocks, Front adjustable swaybar links, Rear Rancho shocks, rear 6.5 inch shackles, Rear Quick disconnects swaybar links, Black rims, Hidden hitch, Husky mud flaps, Trasko spin on filter, No intake resonator, Enlarged 3" snorkel opening, No muffler
Old 04-02-2007, 03:26 AM
CrisB's Avatar
Does it look like a kitty?
Old 04-02-2007, 03:52 AM
Nope, one inch. I'll post pics later, I'm going to go put the front shocks on now.
PS it was a beotch. Needed a little grinding.
Old 04-02-2007, 04:13 AM
TA8088 TA8088 is offline
TA8088 is off the scale
Interested to see how this turns out. Are these shackles available or were they custom made?
Old 04-02-2007, 07:02 AM
Mine are a prototype. But he will be making them.
Old 04-02-2007, 07:10 AM
Cool. Will check back for pics.
Old 04-02-2007, 07:49 AM
Size:  41.6 KB of your truck!
Old 04-02-2007, 04:08 PM
Here's a couple, It got dark before I could take some completed shots, I'll post them tonight.
Old 04-02-2007, 04:09 PM
on......
Old 04-02-2007, 05:49 PM
evldave's Avatar
evldave evldave is offline
evldave is off the scale
What thickness plate are you using for those? It's hard to tell in the pics, maybe 1/4"?
Old 04-02-2007, 06:34 PM
You are correct sir.
