Old 04-15-2007, 08:32 PM
MiamiH3 MiamiH3 is offline
MiamiH3 is on a distinguished road
Default H3 Towing Help
I know the H3 Towing Limit is 4500lbs., but I was wondering if anyone out there has towed anything slightly higher than this with their H3? I am getting an RV trailer, but it weighs about 4300lbs empty. I currently have a POP-UP Trailer that it pulls perfectly well, but it weighs about half of this new one we are intending on getting.
If you know of anywhere I can get some info on this please let me know.
Old 04-16-2007, 12:58 AM
Matt19's Avatar
Matt19 Matt19 is offline
Matt19 is off the scale
Default Re: H3 Towing Help
if im not mistaken, towing capacity takes account the weight of the hummer, the average size of 4 people, and luggage. 45000 Is the max, more than that will make the transmission keep skipping, or changing continually. Eventually very quickly burn out the tranny.
The transmission is set to change gears at a certain speed and power the engine is busting out. So Adding more weight will screw with everything.
Let me digress to another story
My dad was towing my H3 on a trailer with his 2500 Chevy. H3 killed that chevy, two heavy. The transmission kept changing gears to find the perfect one, which it just couldnt find. So He got a 3500Chevy. Vola=)
2007 Black H3, Adventure Package, Chrome Appearance, Chrome Cross Bars, Moonroof, Tow Package, Chrome Tubular Assist Steps. "My golly, this is by far the best looking 2007 H3 you will ever never witness"
My H3 is gods gift to man.
Old 04-16-2007, 01:15 AM
HoosierH3's Avatar
HoosierH3 HoosierH3 is offline
HoosierH3 is on a distinguished road
I'd tend to agree with Matt19. Very well written. You don't want to push the limit to far. I've only had the chance to pull about 3500# so far with no issues. I did install an electric brake controller which helps considerably on the stopping part. On the other hand though, I would think that GM placed the actual limit modestly, that the H3 could actually handle a little bit more weight?? so if your close, it may be ok? Obviously, I would not advise going to far over though....
06 H3 Slate Blue Lux sunroof tow package monsoon stereo w/285/75/16
Old 04-16-2007, 01:41 AM
The total Dry Weight of what I want to pull is 4,439lbs. Add about 400-500lbs of accessories, so I will be pushing close to 5,000.
I will be adding Weight Idstribution and Sway Bar for sure and thinking about electric brakes.
The Hummer web site does say if you plan to pull more than 5,000lbs use a weight distribution and sway control.
Old 04-16-2007, 01:54 AM
In what area of Miami are you?
Old 04-16-2007, 03:57 AM
Huck BB62's Avatar
About towing the H3, I towed ours, with a bed FULL of krap, my 18' car hauler packed full of krap, and the H3 packed FULL of krap from Bfield to Oregon. Grant's pass is pretty harsh. My 2500 did it just fine, but it is a diesel. The H3's only 4700lbs! (I had about 10k on total)
As far as towing 5000 lbs. One thing that bothers me on the H3 is no tow/haul mode. They put this on every other GM vehicle I have. It changes the way the tranny acts. You can do this yourself, just row the shifter by hand. Start off with the load slowly, it REALLY saves the clutches in the tranny. Let your engine wind up pretty high before you go to the next gear. When you're stopping, downshift with it to aid in stopping too. The tranny's plenty tough enough, and the dang axles are surely low geared enough, it's just not supplied with the tow/haul mode. If you're in doubt, put the biggest stacked cooler you can buy on it.
Put a finned aluminum rear diff cover and use synthetic (the shop guys tell me that synthetic's in there from the factory, who's to say?). Tests have shown that these two things lower operating temps a LOT.
Pump up the tires to maximum, this really helps the way the H3 will handle during the tow.
Get a Prodigy brake controller and make sure your trailer brakes are well maintained and adjusted.
No problems. KEEP YOUR SPEED DOWN. Bad things happen so fast when you're towing too fast. One of the absolutely worst things to do is to too lightly load the tongue. I bought a tongue gauge. You should always have 10% of the trailer weight on the tongue. If you don't, it's going to be sway happy and swat you badly.
Think about it, that tranny's used in half tons. 225hp is far more than a 350 had during the 70s.
Trailer brakes are required on anything over 2000lbs here in Cal, they should be everywhere as far as I'm concerned.
Old 04-16-2007, 04:11 AM
evldave's Avatar
evldave evldave is offline
evldave is off the scale
I've pulled 6k for about 70 miles. First part was winding country roads (30-45mph) the last half was freeway (60-70). Powerwise it was fine. Control was fine (it was a flatbed, with a larger trailer I'd be concerned). The biggest issue was the tranny and keeping it in gear. Plus I'd say the tranny has never been the same. Sure, it's under warranty, but I'd highly recommend AGAINST towing a trailer that large on a regular basis.
Just my experience and 2 cents. If I was towing a trailer that large regularly, I'd get a 3/4 ton vehicle - sure you can probably do it, but you are at the maximum range of the truck and have a higher likelihood of 1having an issue - why not get yourself an H2 and have some piece of mind
Old 04-16-2007, 10:51 AM
The trans does NOT have synthetic fluid from the factory. The diffs do!
As for synthetic helping trans shifting...that has never been proved in an automatic. Trans fluid is a heck of a lot more than a slippery fluid. It has to be slippery, but also have enough friction material to make it not cause slippage.
Old 04-17-2007, 06:31 AM
Huck BB62's Avatar
I guess I never made myself clear, I was talking about the rear diff with the synthetic. This does bring up another couple of points though. Synthetic tranny fluid is available. I use it in everything I have, the Royal Purple. In my Allison, my gauge dropped some. It's not a very wide range gauge but from what I experienced, it shifts smoother, and runs cooler.
More about towing with the H3: Never ever ever let it tow between gears. This is when it's not locked up and it's making a lot of heat. If it won't hold top gear, don't try to make it. Just shift it down to a gear that it'll stay locked up in. If it's huntin', rev it!
Old 04-17-2007, 09:23 AM
H3 Alaska's Avatar
H3 Alaska H3 Alaska is offline
H3 Alaska is off the scale
I'll chirp in with a non technical burst here?..both of my H3?s cry like a baby when I pull a 2 place snowmachine trailer with 2 Skidoo Renegade 800?s on it.
Going up hills is the issue (constant shifting even when holding it in ?3?), on flat ground it?s not an issue with this kind of weight; 500 each with fuel, 800 on the trailer, 500 in people, 100 in gear = ~2400lbs going from sea level to 400? over 80+ miles.
I?m not dogging GM here (for gods sake I have my own mini team Hummer in the driveway), but what I am saying for sure is that the weight I mention above puts unnecessary wear and tear on the tranny for sure in my situation.
When an Alpha shows up on the lot?..one could bet it will get tested with the above hooked to it??
2006 White H3, Adventure package, stock for now, 2006 Black H3 Adventure package with a few extras.
Old 04-17-2007, 10:43 AM
H3 without trailers, up and downshifts like crazy when on two-lane mountain roads.
As for the Alpha, it will have the same transmission.
Old 04-18-2007, 10:06 PM
sltbluh3's Avatar
sltbluh3 sltbluh3 is offline
sltbluh3 is off the scale
I've pulled a trailer wieghing about 2800 pounds from Charlotte NC to Orlando FL. Some of the hills was steep 6-7% grade the tranny downshifted into 3rd and hung right there. MY speed slowed down but all in all it pulled better than my old Z71.
Slate Blue, Luxury Package, Chrome Package, Chrome Rims,XM,Chrome step tubes,trailer package,Air Raid throttle body,SMA cold air induction,GHL Exhaust
Old 04-20-2007, 03:46 AM
Urban Ops's Avatar
Urban Ops Urban Ops is offline
Urban Ops is on a distinguished road
4,500 lbs. plus camping gear and peeps, 2,000 miles round trip to Moab and back. No problems and 12 miles to the gallon.
Master Sgt. Art Lilley 1972-2007: The perfect example of what a man should be.
A brave man and a fellow four wheeler dies for us
My son and I will both miss you greatly Art. Thanks for everything!
