Old 04-15-2007, 10:53 PM
Hal's Avatar
Hal Hal is offline
Hal is off the scale
Default Extra Cargo Space Rear Door Modification
By moving the jack over to the right you can access much more space inside the rear door hatch.
Position of jack before......... and after:
Size:  73.9 KBName:  hummer3 004.jpg
drilled 3 new holes and fabricated 2 simple brackets and can now fit twice as much stuff inside!
Size:  71.3 KBName:  hummer3 002.jpg
an hour or two well spent
Shadow Green 5-Speed/GREEN GRILLE/rear door AIR compressor/Factory Nav/Lux-Off Road Pkg/Sunroof/Roof & Grille Off Road Lights/Underbody Protection/Wet Okole seat covers/Husky floor liners/Black fuel door/No Chrome/'04 Grand Cherokee Overland/'94 Isuzu Rodeo 4x4 lifted.
Old 04-16-2007, 12:43 AM
fourfourto's Avatar
Default Re: Extra Cargo Space Rear Door Modification
Thats a good idea
I got lots of stuff back there,even added a few things since pic.
A little over 15lbs of stuff.
Name:  jack comp stuff.JPG
Name:  jack stuff.JPG
Old 04-16-2007, 04:55 AM
Hunner's Avatar
Hunner Hunner is offline
You got a shot of the two simple brackets?
Old 04-16-2007, 03:38 PM
Hal's Avatar
Hal Hal is offline
FIRST pop off the entire lower interior rear door panel for easy access.
brackets are just 2 stout pieces of metal shaped/bent to work like the factory mounting points (which are far to the left, out of this picture). They are attached with small bolts thru 2 holes drilled in the sheet metal. Also in this picture is the original hole that the long jack-screw-bolt went thru, now no longer used.
Here you can see I drilled a new center hole to the LEFT of the original jack-screw-bolt hole. Then simply move the black clip/nut fastener thingy to the NEW center hole as shown here.
NOW, Look back in my first post, the lower left photo shows the three old and three new mounting points. Note that the jack will be flipped 180 degrees to keep the white jack-screw-bolt-knob close to the center of the hatch opening.
notice that a full anifreeze gallon jug fits perfectly in the new space plus a whole lot more, tow strap, quart of oil, WD-40, folding shovel, bow saw, and there is still space for more on top of all that.
Old 04-16-2007, 07:02 PM
aaaahhhhh snap! I like that! will be my next weekend project!
Old 04-19-2007, 08:52 PM
Hunner's Avatar
Thanks I was thinking of trying something. Good idea. Amazing what you can cram in there. I pad mine with gloves and straps so I don't get a clunk everytime I bounce.
Old 04-19-2007, 09:01 PM
BigPoppa1411's Avatar
Thats cool! I never even thought of using that space! Thanks guys!
Old 04-21-2007, 02:34 PM
Crash ?'s Avatar
Crash ? Crash ? is offline
Sheesh... I keep forgetting about all that space back there.. Move that jack over a bit and the air compressor might become a back door fixture rather than a garage one..
Rob
Old 04-24-2007, 03:17 PM
Hal's Avatar
Hal Hal is offline
click this link and see what else fits easily in the rear door now! http://www.elcovaforums.com/forums/s...ad.php?t=26431
