Old 04-20-2007, 06:36 PM
Default Re: Tie Rod
You know, since I know Sewie and the Bullies have extras, how 'bout I just hop myself down to Fed-Ex on my Lunch?
PM me your address....
Old 04-20-2007, 07:10 PM
Desert Dan's Avatar
Default Re: Tie Rod
Are there any Machinists out there?
Where are the aftermarket HD tie rods somebody?
I am sure the would sell like hotcakes.
Desert Dan
Jeep TJ Rubicon 2003
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
Old 04-20-2007, 07:56 PM
fourfourto's Avatar
Default Re: Tie Rod
How about brace or something to beef it up,bolt on without removal if possible.
Old 04-20-2007, 08:46 PM
Default Re: Tie Rod
How about a piece of Lead Pipe???
Old 04-20-2007, 09:07 PM
ChasH3's Avatar
ChasH3 ChasH3 is offline
ChasH3 is off the scale
Default Re: Tie Rod
Originally Posted by inked
Hey ChasH3 you did okay on the trails with that welded tierod? Here's a pic of mine, what do you think this is good enough for the trails? I placed a clamp over the inner and outer tierod to keep it from spinning, because mine broke at the threads my friend who welded it had no choice but to weld over the threads, we couldn't put the nut back on.
I haven't taken my rig over 45mph yet only because I wouldn't want it to snap on the freeway, but everyone is telling me that the welded side is actually stronger than the stock one. I'm missing out on a big run Saturday because of my freakin' paranoia of it snapping it, I dunno man, it's either paranoia or just the fact that freakin' nobody has any in stock - I hope HummBebe does well on Sunday and sends me her spare (hint, hint!)
I only ended up running the one trail.. There were some places along the trail that if I would of broke the tie rod again, getting pulled out would of caused some body damage... The bolt that is attached to the outside part of the tie rod, was a bolt I found in town at the local hardware store... Cut the head off the bolt and then welded it to the other half... I drove home on the freeway and never went over 55 mph.... I would use the welded one in an emergency, but I wouldn't continue wheeling with it attached...
Old 04-21-2007, 02:40 AM
inked's Avatar
inked inked is offline
inked is on a distinguished road
Default Re: Tie Rod
Just sent you my address - Thanks again HummBebe!!
- 4X4BOYZ.com - MULTI - 4X4 VEHICLES - GET IT DIRTY
Old 04-21-2007, 02:17 PM
Crash ?'s Avatar
Crash ? Crash ? is offline
Default Re: Tie Rod
Hunner.. You and Phil need to get together and find out it these will work with an H3...
http://www.trailduty.com/product_inf...roducts_id=237
They are made for GM 1500/2500 series trucks...
Rob
Old 04-21-2007, 07:07 PM
Huck BB62's Avatar
Default Re: Tie Rod
These guys here, they could, and would make 'em. http://bulletproofsteering.com/gmifstierod.html
Don't the H2 guys have this all figured out?
Old 04-21-2007, 07:57 PM
Default Re: Tie Rod
Shipped, be there Tuesday
Old 04-23-2007, 10:27 PM
movaltow movaltow is offline
movaltow is on a distinguished road
Default Re: Tie Rod
called bullet-proof they need thread size at rack. does anyone know what size
the are. these look heavy duty!!
Old 04-24-2007, 01:13 AM
Default Re: Tie Rod
anyone have any bent/broke tie rod ends?? need samples to have some built
let me know tukrhum@myway.com
Old 04-24-2007, 06:06 AM
Hunner's Avatar
Hunner Hunner is offline
Default Re: Tie Rod
I don't think I see any grease zerts. How long will Hime joints last without grease? I know Skyjacker struts and track bars on Jeeps wear out quickly on the street. I will look at that somemore and see if I can find how to contact them with measurements just to run the scenario. I looked at some full size pickups and they are longer and not impressively bigger if at all.
SUMMARY OF THE INVENTION
The connected joints of the prior art comprise a plurality of articulated joints henceforth individually referred to as a ball joint. Dimensionally, the Hime Joint is similar in size to a conventional ball joint or tie rod end found in selected vehicle suspension systems. While it does offer the rotational capability of the ball joint, it lacks the connecting insert to allow it to act as a ball joint or tie rod end. The newly invented tapered, or alternatively, straight insert provides that added capability.
When the conventional upper and lower ball joints or tie rod ends are replaced with the Hime Joint and the newly invented tapered or straight insert is installed, new and unexpected results occur. The Hime Joint, when fitted with the newly invented tapered or straight insert provides proportionally greater vertical and or horizontal travel. This extra travel results in a dramatically improved suspension system; one that is up to eighty percent stronger and weighs less than the conventional ball joint system. Additionally the unsprung weight of the suspension system is reduced and handling is vastly improved. Friction is also greatly reduced compared to the conventional style ball joint.
Old 04-24-2007, 08:08 AM
Default Re: Tie Rod
Source?
Old 04-24-2007, 05:15 PM
Default Re: Tie Rod
Somebody should be getting their tie rod today....
Old 04-24-2007, 07:09 PM
inked's Avatar
Default Re: Tie Rod
Hey HummBebe I owe you big - will let you know if I receive it!
Thanks again!
Old 04-24-2007, 07:27 PM
Default Re: Tie Rod
HONOLULU,
HI, US 04/24/2007 8:21 A.M. OUT FOR DELIVERY
Huck BB62's Avatar
Default Re: Tie Rod
Just drill and tap it for a zerk. No big deal.
Old 04-24-2007, 10:39 PM
fourfourto's Avatar
Default Re: Tie Rod
Inked owes Bebe a Rod
Old 04-24-2007, 10:50 PM
Default Re: Tie Rod
Old 04-25-2007, 04:55 AM
Hunner's Avatar
Default Re: Tie Rod
Originally Posted by Sewie
Source?
I googled Hime joint
All my present and past fellow race car mechanics all said today that Himes would wear out fast. I do recall on Formula Fords and Formula Bs that was something checked and replaced often. Neat while they work though. Surely aftermarket manufactures will catch up as time goes on. Im trying to find some alternative way to beef them up. I can't believe I have not hit one on something yet. Are the ones that have broken been hit or is it spinning tires and then getting traction breaking them??
