Old 03-26-2007, 12:29 AM
ChasH3's Avatar
ChasH3 ChasH3 is offline
ChasH3 is off the scale
Default Re: New Eaton Locker added to Base H3
Originally Posted by ETD
Damn. Too bad. I guess I'll do the count down at Moab till mine breaks. It didn't seem that hard to change 'em on the trail at Katemcy last year...
As far as the locker, though, I am calling my dealer tomorrow to see if they can put one in. Did your dealer supply the needed bearings to install it or did you get that as well. thanks for the info.
ETD, the dealer provided the new carrier bearings... had them in stock...
Old 04-05-2007, 01:21 AM
ETD's Avatar
ETD ETD is offline
ETD is an unknown quantity at this point
It's here at the Dealer. Will get installed with ReadyLift Front leveler (too bad the Cognito/Bilstein Shocks aren't available at this time as well). Can't wait .
Old 04-06-2007, 02:48 PM
ChasH3's Avatar
ETD, I had the Readylift put on the H3 over a month ago... I have had no issues with the product...
Old 04-20-2007, 01:54 AM
ETD's Avatar
ETD ETD is offline
Ok. Tomorrow the Dragon will go in for the leveler and the locker. A little L&L
Can't wait to see how she'll climb this week-end.
Old 04-23-2007, 04:26 PM
hummer.h3 hummer.h3 is offline
hummer.h3 is on a distinguished road
Hi guys, Please need help!!!!, I also seen the elocker on trailduty, I was under the impression that rear diff on my h3 hummer was a 10 bolt 7.5" and not a 8.5" Did the dealer have to do anything special to fit the Eaton Locker. I want to buy this locker but I want to be sure it fits.
Old 04-23-2007, 09:37 PM
movaltow movaltow is offline
movaltow is on a distinguished road
rear axle is gm 8.0 10 bolt 8" ring 28 spline c-clip axles
front is gm 7.2 reverse cut 10 bolt cover.(p.o.s)
i am looking for gears for mine. hard to find
Old 04-25-2007, 09:26 PM
ChasH3's Avatar
No the dealer didn't have to anything special to make the locker fit.. The Eaton Locker I ordered from Trail Duty had everything required to hook it up... I even had them locate the on/off button for the locker where one of the factory light buttons would go... Very clean... If you need a picture let me know....
Old 04-26-2007, 03:55 AM
ETD's Avatar
ETD ETD is offline
Got it back from the dealership today levelled and locked .
Will try some climbs tomorrow to see how it works.
Here's what I was charged (don't know whether it was reasonable or whether I got takened to the cleaners )
Part# Part QTY List Sell Total
009418390 Bearing 2 114.84 76.08 152.16
089021677 Gear Lubr 35 29.72 23.72 71.16
011509086 Strap-tie 125 2.64 1 12
NPN 19659-1 E-locker 1 1295 760.95 760.95
Labor 405
Interesting that they put the button on the auto-shifter console and not use one of the buttons available under the radio. But the yellow button does look cool next to the shifter.
Old 04-26-2007, 04:14 AM
ChasH3's Avatar
Labor 405
ETD, Congrats......
Old 04-26-2007, 04:39 PM
H3less's Avatar
H3less H3less is offline
H3less is off the scale
Don't mean to highjack just got a question on the readylift, you say no issues, did you have the dealer install/ I assume that it would correct any/ all related potential issues with cranking the tortion bar? I am thinking of having the dealer put them on when I take delivery on mine.
Old 04-27-2007, 12:21 AM
ETD's Avatar
ETD ETD is offline
Yes, had dealer installed it. They were nice enough not to add the labor of that to the labor for installing the locker. BTW, went to the local playground and tested the locker and level. A word of caution on the installation of the lockers. It took longer than the 4 hours that was promised me by ~ 72 hours!! So far so good. Boy those climbs are easier . Might lose my driving skills using dem lockers in MOAB .
Old 04-27-2007, 05:36 PM
H3slate's Avatar
H3slate H3slate is offline
How do you like the ride with the level kit? Any noticeable changes to ride quality, dipping when braking and cornering?
Old 04-29-2007, 01:50 AM
Hey ChasH3 thanks for the info:
Old 04-29-2007, 09:18 PM
ETD's Avatar
ETD ETD is offline
Can't say yet. Was out of town, again. Will let you know once I have driven it a while.
Old 06-14-2007, 01:25 AM
H3telcobilly's Avatar
H3telcobilly H3telcobilly is offline
H3telcobilly is on a distinguished road
Is there an upgrade path for the front alum diff after the rig is out of warranty?
Bill, '07 H3 Birch White,auto, Husky floor liners,pre runner brush guard more to come.
Old 06-14-2007, 11:15 AM
Wisha Haddan H3's Avatar
A lot of people here are hoping to upgrade the aluminum case to the cast iron one from the 08 alpha. The gears are different, but any good shop could set up your old gears in the new case.
I wonder ... since it's all GM, it might not void your warranty either. But if you let a dealership do the work, you'll at least get their standard 1-year on parts.
Old 06-15-2007, 09:36 PM
ETD's Avatar
ETD ETD is offline
No noticeable change in ride quality. No dipping when braking and cornering around town. (Drove it for a few weeks then went to have realignment.)
Old 06-15-2007, 10:15 PM
ETD's Avatar
ETD ETD is offline
Hey ChasH3, as I think about it a little more, do we disengage traction control when engaging the rear locker to climb and such?
