Old 05-04-2007, 08:32 PM
audiofetish's Avatar
Default H2 Snorkel
I was looking on EBay and saw this. I couldn't stop laughing.....
http://cgi.ebay.com/ebaymotors/Humme...ayphotohosting
Hopefully not from anyone here.
09 Challenger R/T
95 Heep Wrangler
90 5.Slow
99 HMC4 Sold
01 HMCO Sold
04 H2 Adv Sold
03 H2 Lux Totaled
HOPE Volunteer
Old 05-04-2007, 08:34 PM
Dan Dan is offline
Default Re: H2 Snorkel
I think that's Spike's truck...
Old 05-04-2007, 11:55 PM
thats nice!!!!
Old 05-05-2007, 03:25 AM
AUHUMMER's Avatar
AUHUMMER AUHUMMER is offline
AUHUMMER is off the scale
I think those come with torpedo tubes to mount in the DRL locations and a grenade shifter.
The bad thing is, if they offer it in chrome they won't be able to make enough of 'em.
Old 05-05-2007, 03:58 AM
MarineHawk's Avatar
It's quite a performance enhancer, since it "bring[s] more air into the sidewall/ engine compartment." Man, why didn't GM think of that!?!?
Old 05-05-2007, 05:57 AM
Vettster Vettster is offline
Can you say STOOPID?
Old 05-05-2007, 06:14 AM
You're kidding, yes? You do know what's under there?
I just went out and took this just for you.
Old 05-05-2007, 12:36 PM
mikejr's Avatar
mikejr mikejr is offline
you must not have the hybrid fusion generator option on yours thats why there is nothing under that cap.
2009 H2 Silver Ice LE
Old 05-05-2007, 05:01 PM
Hummer Guy's Avatar
Hummer Guy is off the scale
-Brian
http://www.hummerguy.net
Old 05-06-2007, 07:21 AM
DRTY is right you cannot pull air through the fender system very easily in that location. You can relocate washer tank then cut hole that will go to engine bay.
You can use the caps to add screens in front. Make a rubber seal so that when you pop cap on you get a ram air type system once you also make a new intake tube to air filter. With supercharger not really looking for ram air but, coolest air. This is a MOD Dragon and i have already figured on doing next. Just rough look and drawing as we are not there yet. Still need to figure a rain drain into the system like a small U in the line before filter with a drain in it. Do not want to disrupt air flow to much so not sure how we will do the drain yet may just take air from a dry location up top. Plus my Mall Queen does not see ugly weather anyway though you never know when you may get caught off guard. Will not be to hard to figure it all out but, will retain the stock look. Any suggestions welcomed though. Thanks for sure for those!!
It would not be a great snorkle unit but, air intake would be up a little higher. Most likely higher than someone would want to ford water that deep I guess.
Well anyway just a thought.
TAZ
Old 05-06-2007, 08:37 AM
drmiles's Avatar
drmiles drmiles is offline
drmiles is off the scale
RAM AIR INDUCTION TOWERS FOR H2
BREATHLESS PERFORMANCE PRODUCTS- These custom towers incorporate a stainless steel mesh opening that when used with the Vortex Ram Air Induction System provide a rush of cold air into the engine compartment. They can also be used a dress up item and setup as non functional.
2 minute install and they come color matched.
Item 400-254 Ram Air Induction Towers $ 299.00
To order, call us at Breathless Performance at (954) 925-7725
Our Online Shopping will be ready very soon, and it will give you the extra option of ordering directly our items online.
Old 05-06-2007, 08:45 AM
drmiles's Avatar
Had this ony my 03. You cut a hole in the body panel for the air to flow in to the engine compartment. It brings in cold air, from outside. Need an open air filter box as well.
Old 05-07-2007, 07:33 AM
Hey dr,
We know about these but, we want to do a closed system as the reverse cowl hood scoop is functional. Thinking that if not a closed system the breathless type system will just suck in more mosture and debri as scoop removes allot of heated air fast. Normal air coming in through radiator and front goes around engine and down under rig so breathless type setup would work better then. The scoop changes direction of air flow as well as increases the flow. Well anyway i know You get where i'm going with it all. Sorry!
The covers have to be custom color matched anyway so we have figured that we know how to cut and add screen which will make it all done for little or nothing. We have to add some tubing in correct size an shape to fit the cold air kit, then enclose filter in a round canister, and an overall flow design thinking ahead of removing the MAF when boost get's past 15lbs. of boost. That and more stuff will come up not yet forseen. On the driver side I will do an open cap and just cut hole out to help lower engine bay temps working with the reverse cowl scoop.
With the SC intake direction, water/meth kit, co2 bottle to cool down aftercooler and some other stuff like SC cooling pump etc. room is limited. We have had to already rework the cold air kit some to fit space allowed. We will have to make a round canister for conical air filter so as to get it to a closed system along with coming up with a rain drain and maybe a heavy debri catcher also. The large tractors I owned had just ahead or on the leading end of the canister a 2 inch round drop tube with a rubber duckbil shaped drain that let water out as well let You squeeze it and make larger heavier trash drop out that would collect ahead of air filter. It worked well on the slow tractors but, it would have to be tried at faster speeds to see if the intake air will slow down enough for trash to fall into drain as well as water. I'm thinking water will if it is not atomized to much going through screen and turns. I would hope water would collect on tube walls and fall to bottom side of tube and into drain. If not it will be filtered and maybe less water in methanol inj. LOL
I'm also not sure i want forced air into SC so i'm thinking of turning and putting both cap screens on back side so filter get's colder air and the driver side just helps to remove more engine bay heat.
I have a design in mind we just have to try it and make adjustments. Part of the fun I guess of doing something different though it is a little nerve racking at first try, yet fun when you beat the problem.
Thanks dr for making me think about it more as we knew we could do the screens for next to nothing. You got me to thinking about harder. It has been on the back burner for a long time now.
TAZ
Old 05-07-2007, 04:02 PM
Diceman's Avatar
Diceman Diceman is offline
Diceman is on a distinguished road
Thats where my Flux Capacitor mounts on my truck...no, seriously
Old 05-07-2007, 06:39 PM
Next to the goggles that come with the snorkel kit.
09 Challenger R/T
95 Heep Wrangler
90 5.Slow
99 HMC4 Sold
01 HMCO Sold
04 H2 Adv Sold
03 H2 Lux Totaled
HOPE Volunteer
Old 05-07-2007, 06:50 PM
This is how I think a snorkel could be done:
You'd have a rubber flange that would fit over the air screen under the hood, and then the snorkel and all would lift up with the hood.
Old 05-08-2007, 05:39 AM
finbox finbox is offline
finbox is an unknown quantity at this point
That's cool looking... i think I will get two of them.....
Old 05-08-2007, 05:36 PM
Even if you cut a hole there the space below doesn't go to the engine compartment.
