Old 05-03-2007, 04:14 PM
evomind2 evomind2 is offline
evomind2 is on a distinguished road
Default 2003 h1
hey folks,
i havent been around for awhile, but im back.
i may have the opportunity to buy a 2003 h1 with 2k miles on it.
my best guess is this truck would be worth abt 65k?
also, i would like to put the 4" lift on it with 38" tires.
any other upgrades you folks feel are necessary for an 03?
i do intend to offroad it from time to time.
thanks
Old 05-03-2007, 05:53 PM
Ground hawg's Avatar
Ground hawg Ground hawg is offline
Ground hawg is an unknown quantity at this point
Default Re: 2003 h1
I wouldnt do the 4" lift if your only going to put 38s on it. to much hastle with the wires and othere sh/t. use the suspension lift from blue hummer. other mods depend realy on where you intend to off road, and how much you want to outlay cash wise.
if you goin through lots of trees get a better brush guard and light bar, with a branch wire either side. its amaizing how fast a brach will take out a window. if your going on thr rock trails you can beef up the center cross member and get some more under carage protection stuff.
Old 05-03-2007, 06:23 PM
Default Re: 2003 h1
i wasnt familiar with the suspension lift from blue hummer. any link on that? ill check it out.
i was only gonna go 38's cause i dont want to regear the thing. i kinda think 38's are big enough for me anyhow.
planned on doing some undercarriage protection....
good idea on the brush gaurd.
Old 05-03-2007, 08:33 PM
Default Re: 2003 h1
http://www.bluehummer.com/ Here you go, Dave's got good rates on his gear, and he usualy gets it to you quicker than going to any dealer i know of.
Old 05-03-2007, 10:15 PM
Default Re: 2003 h1
thanks ground hawg
Old 05-04-2007, 04:36 PM
It\'s a Dry Heat's Avatar
Default Re: 2003 h1
Front Eaton locker.
Vern
Old 05-07-2007, 10:10 PM
Default Re: 2003 h1
i plan on doing the front locker, and undercarriage protection, where im kinda undecided is the lift.
i kinda want to do the 4" lift, with bigger tires....
does this change the driveline geometry?
where do i get the gears to account for the bigger tires?
what other parts will i need to do the job complete?
like if i go with 40" tires, do i need new wheels? (i wanna keep ctis)
do i need a longer steering shaft, etc etc....
also, has anyone tried and or know of anyone who has had success with the ecu upgrades??
thanks
Old 05-09-2007, 08:02 PM
Default Re: 2003 h1
ok, i thinking of going with the stage 3 lift kit from rubber duck.
its a 4" suspension lift with a 2" body lift....
probably run 39's or 40's.
http://www.teakatoys.com/Hummer_H1_S..._p/rd-1-15.htm
what do u guys think? any knowledge on this setup?
any thoughts suggestions???
Old 05-11-2007, 05:58 AM
Default Re: 2003 h1
You should ask these questions on Humvee.net or query the Hummer Knowledge Base there. There really is much more H1 information there than you will find here.
Personally, it's an H1, you don't need a lift. Just armor it up, deck it out with cool stuff, and drive it smart. Lockers are a nice addition though!
Old 05-11-2007, 07:03 PM
Default Re: 2003 h1
No lift man you don't need it! trust me! be careful on tires if you wan tto use the CTIS and the two piece rim. I am not a fan of mods on the H1 unless it's a bitch mobile.
Old 05-11-2007, 09:26 PM
Default Re: 2003 h1
theres very few things in life we NEED.
