Old 05-10-2007, 05:17 PM
jdrew's Avatar
jdrew jdrew is offline
jdrew is on a distinguished road
Default Underbody protection install
ok... i have been working at these for 2 hours and cant get the DAMN front bolts to grab.. they are in NOW WAY long enough to go through the skidplate, underarmor and crossmember... What the hell gives?
Anyone have any ideas?
Evansville, IN
'05 H2 SUT Slate Blue LUX w/Nav, NightDriver
H.O.P.E. Member
Old 05-10-2007, 05:23 PM
Default Re: Underbody protection install
I've never had a problem with the front bolts. But then I put the front on first.
Old 05-10-2007, 05:37 PM
jdrew's Avatar
they maybe stick out 1/8th of an inch with is about 1/8th short of being able to grab the threads...
the rear went on very easy... dunno... oh well.. off to the fastner shop for some longer ones..
Evansville, IN
H.O.P.E. Member
Old 05-10-2007, 06:08 PM
jdrew's Avatar
im missing the 2 extra bolts in the packing..
Evansville, IN
H.O.P.E. Member
Old 05-10-2007, 06:11 PM
You might have them backwards. I think the front are longer than the back.
Old 05-10-2007, 06:14 PM
deserth3's Avatar
deserth3 deserth3 is offline
Sounds that way. Those 2 bolts are longer. If I remember right there should also be a spacer and a normal size bolt with a nut. Also make sure you got the instructions.
Old 05-10-2007, 06:39 PM
there is a spacer bar ( short steel bar ) . i had to leave mine pretty loose and beat some stuff with a sledge hammer to get where all would start . after all bolts are in then tighten it up . a milk-crate works good to help hold it up while getting everything aligned and bolts started .good luck it can be pretty tough
Old 05-10-2007, 07:46 PM
If I wanted to show my welder friend a diagram of one so he could make it. wehre do you think I may find it.
Old 05-10-2007, 10:29 PM
jdrew's Avatar
Thanks for the replies... I was missing the bolys from the get-go.. i looked on the instructions and i was supposed to get 2 mx38 bolts.. i ran to chev and they had some.. so all good... bring on the rocks..lol
Evansville, IN
H.O.P.E. Member
Old 05-11-2007, 12:25 PM
Crash ?'s Avatar
Crash ? Crash ? is offline
Yeah they are a PITA to get on... I spent about 3 hours trying to figure it all out.. I bought a set off a rack at the shop, no instructions, no bolts..
I started in the back and worked my way forward.. I had to use a jack under the front part of the skid plate to get up pressed up enough the bolts would grab...
Rob
