Old 05-19-2007, 02:11 AM
Default my rearend
Name:  051807_02 (Small).jpg
Sorry to disappoint you perverts.
Old 05-19-2007, 02:16 AM
fourfourto's Avatar
Default Re: my rearend
You have some seeping out your plug hole
Old 05-19-2007, 04:16 AM
Is that Martha Stewarts crackle effects on the back or is your dif cover cracked
Old 05-19-2007, 04:31 AM
I'm not sure what's up with that. I didn't notice it until I took the pic. I just picked up my truck this afternoon after having the rear axle replaced so I'll have to check with them on Monday.
Old 05-19-2007, 04:56 AM
marin8703's Avatar
why'd you have it replaced? did i miss something? my diff has some of those crack looking things too, i think its juts the casting process and not really a problem, but not sure.
Old 05-19-2007, 06:21 AM
Chipped some teeth in the diff - on one of the spider gears I believe. I didn't get to actually see the carnage this time since they had already put the cover back on the old axle and had it packed up ready to ship back.
The tech also said he found lapping compound in the diff. Kinda surprised since I have 36K+ miles. You'd think it would've caused a failure a long time ago. But whatever it takes to get it replaced under warranty with no questions asked.
Old 05-19-2007, 06:46 AM
Glad there's no pics.
Old 05-19-2007, 01:00 PM
I must say, I am a little dissappointed.
Old 05-19-2007, 01:45 PM
JUST FOR YOU...
Old 05-19-2007, 06:23 PM
Here's a good one.......
Old 05-20-2007, 12:03 AM
Dripping out of the top (fill) hole is usually not a concern. However, dripping out of your lower (drain) hole is a problem,
Old 05-20-2007, 01:02 AM
Brian H's Avatar
Brian H Brian H is offline
Brian H is off the scale
Slap a Depends diaper on there and you're good to go! That should take care of the seepage.
HUMVH3
Old 05-20-2007, 02:17 AM
Old 05-21-2007, 05:05 PM
H3.007 H3.007 is offline
Sewie - as one of the few "docs" on here, may I recommend some Preparation H for the cracks and a box of Depends for that leak
Old 05-21-2007, 10:44 PM
Old 05-22-2007, 01:51 AM
No worrries doc, it was just a case of swamp a$$, 20 hours in the saddle....know what I mean?
Old 05-22-2007, 02:30 AM
Bwahahaha!
Well, KY will take care of that there saddle blister!
Old 05-22-2007, 04:25 AM
Old 05-22-2007, 06:04 AM
Attachment 40038
Bwaaaahahaha!!!
you're a dik
how much of that sh1t do you have??? Obsessed much???
