Old 05-18-2007, 09:03 PM
Default Re: New Bilstein / Cognito Hummer H3 Leveling Front Shocks???
Originally Posted by tomp
Ok, I will try. However, I understand them to be high pressure charged and may be kind of difficult depending on the PSI they used
You will see a line at the bottom Measure from there.
Old 05-19-2007, 06:23 AM
I just ordered a set tonight. We'll see how they do.
Old 05-22-2007, 04:38 AM
tomp's Avatar
tomp tomp is offline
Ok, shocks arrived today. Wasn't sure where to take measurements from, so I took them from the tip of the threaded end and to the center of the bolt hole on the other end.
Didn't have time to install, but will get to that hopefully tomorrow...
The shocks measure 15.5" compressed and 21.75" uncompressed using the method above. Please let me know how this compares to stock and Rancho shocks. thanks!
Old 05-22-2007, 06:02 AM
Here is the Rancho Specs....
2006 Hummer H3
Front shock IFS
Compressed length 13.43 Extended length 15.77
2.34 Travel
Rear Shock S
Compressed Length 15.25 Extended length 23.49
8.25 Travel
Now for the Avalanche 4" lift for front replacement:
Front shock IFS
Compressed length 13.875" Extended length 20.75"
6.875 Travel
Rear Shock Suburban 4" lift shock
Compressed Length 15.875" Extended length 26.25"
10.375" Travel
Link to Part #'s
http://www.gorancho.com/flash/docs/2005_shocks.pdf
Link to Shock Specs
Part numbers: Rancho 5000 Front RS5268
Rancho 9000 Front RS99268
Part Numbers: Rancho 5000 Rear RS5190
Rancho 9000 Rear RS99190
If you look at the year make and model, both shocks have multiple applications. If they ask you what rear and model, defer to the part number.
PLEASE keep in mind Rancho will not warranty these shocks.....they are not being used in their "proper" application.
They will not warranty the H3 shocks either if your Torsion bars are turned, so... meh....
Old 05-22-2007, 06:17 AM
Looks similar. Glad they did it right!
Old 05-22-2007, 05:36 PM
MtnHmr MtnHmr is offline
MtnHmr is on a distinguished road
Just a humble thought from the new guy.
When you compare shocks from different manufacturers you may want to measure from the top of the shock body instead of including the threaded stud in your measurement. The same shock, for the same car, form two different manufacturers may have a very different length threaded stud on the end. So in essence, when you measure, you are gettting the compressed/extended(travel) measurement plus whatever the difference is between the two studs.
I found this to be true when comparing the stock shocks to the Bilstiens. The threaded stud on the stock shock was longer.
I hope this helps
Old 05-22-2007, 05:43 PM
All of those measurements are on the shock specs link above.
And true, he should be measuring the body of the shock.
Old 05-23-2007, 01:22 AM
Wisha Haddan H3's Avatar
Hey Beebs, those links open the same pdf. Where are the specs?
Old 05-23-2007, 02:35 AM
blindzebra's Avatar
I think I'll go with the Foxs when I replace mine.
Old 05-23-2007, 03:55 AM
RuggedH2's Avatar
RuggedH2 RuggedH2 is offline
There is a lot to like about the Fox shocks (except the price).
I was thinking about Fox for the rear axle.
Old 05-23-2007, 04:08 AM
tomp's Avatar
Okay, shocks are on and test drive completed. I drove it around for a while and what a huge difference! Big improvement over stock ride quality, even with TBs cranked!
Old 05-23-2007, 06:05 AM
OOpsie
http://www.gorancho.com/flash/docs/2...shock_spec.pdf
Old 05-23-2007, 06:09 AM
I think, no wait I know that the Fox shock is FAR superior to any of these mentioned in this thread.
Yes they are pricey, but for the amount of money I have spent on shocks I could have bought a set of the Fox shocks.
The fox shocks are rebuildable. If you blow it, you can rebuild it for less than a replacement cost of the other shocks.
Old 05-24-2007, 05:27 PM
Idaho-Hummer's Avatar
Idaho-Hummer is off the scale
ok, I give up, where are you finding the Fox shocks at for our H3's?
Old 05-24-2007, 10:37 PM
H3slate's Avatar
H3slate H3slate is offline
Fox shocks are available from Rod Hall Products. They are not listed on the website, but give them a call. When they are not racing they are very friendly and knowledgable.
http://www.rodhall.com/
1-877-ROD-HALL
HummBebe, have you purchased the fox shocks? I know they were recommended by a suspension guy working on HD torsion bars for the H3, just curious if you have had a chance to try the shocks.
Old 05-24-2007, 11:08 PM
No not yet, but soon. You can also get them from Sam at Samco Fab...
http://www.samcofabrication.com/index.html
He's even nicer
Old 05-25-2007, 01:36 AM
He's even nicer
Damn bebes, is there anyone you DON'T know! Oh, and thanx for the link
Old 05-25-2007, 02:05 AM
Old 05-25-2007, 02:53 AM
SR1355's Avatar
SR1355 SR1355 is offline
Bebes, did you ever get anywhere with Sam and HD Torsion Bars???? Where did you pick up your add-a-leaf kit???
Paul M
SR1355
Old 05-25-2007, 03:52 AM
I actually am ready to oder the HD t-bars now. And when I get everything together, we will place the order.
The spring helpers I ordered are going on tomorrow. Can you believe I still don't have those on???
It's from Hellwig, and they are load pro 15's. http://www.hellwigproducts.com/produ...es/default.asp They are progressive rate springs, so the more weight you add the firmer they get. No weight and you still have a comfortable ride.
