  #41
Old 05-22-2007, 12:26 PM
Crash ?'s Avatar
Crash ? Crash ? is offline
Default Re: Tire Pressure for 35" tires?
Originally Posted by NOMOYELLO
OUI VEY!!!WITH ALL THAT PSI YOUR HEAD IS GONNA POP.....
Really..?? The tires have 45 Max PSI recommended stamped on the side of them I believe.. And I've heard of folks running 50 in them..
Rob
Old 05-22-2007, 01:41 PM
thats kinda like having a SPEED LIMIT of 65 but going 80
Old 05-22-2007, 11:31 PM
JWSchmidt3 JWSchmidt3 is offline
JWSchmidt3 is an unknown quantity at this point
First off, I don't actually know the answer to the question being asked . . . but . . . I don't believe the tire pressure changes with the size of the tire. "PSI" is per square inch, regardless of how many inches is being filled with air. PSI measures the pressure, regardless how large the area of compression is.
I would follow the Min/Max recommendations, seems that everything in between is preference, not necessarily "correct".
J.W.
2006 yellow H3 - Pro Comp Xtreme package
4" lift, 35's, Lux, etc.
2004 yellow Corvette Z06
2002 black LPE blown TigerShark Z06
http://public.fotki.com/JWSchmidt3/
Old 05-23-2007, 12:37 AM
WHAT PSI DO U RUN YOUR 35"ERS??????
Whatever they were filled with at the dealer. Seriously, the PSI on a tire like this doesn't make that big of a difference when filled within their designed operating pressure, for every day use. But that's off the subject of the original poster's question.
Now, if we're talking about my Vette, 32 front, 30 rear. That's a different animal.
J.W.
Old 05-23-2007, 06:22 AM
It is a different animal, but tire pressure is tire pressure.
I'm sure you can tell when a tire might be a little low when tooling around town? I can. 35" tires on an H3 should be run between 36-38PSI.
The higher number is advisable if you have added weight like a winch or are loaded with gear.
THAT IS ALL!
Old 05-23-2007, 08:58 AM
KeyzH3 KeyzH3 is offline
KeyzH3 is on a distinguished road
Most salespeople don't know "CHIT from SHINOLA" ...
be an educated consumer and look up the information
HELL I went to "A" HUMMER DEALER this year and one of the salespeople didn't know the H-3 had a 5 cylinder in it...
Got that right! This will be one of two firsts for my tire guy. First H3 and first 35s. Speaking of Dumass dealers, I just noticed that my dealer butcherd up my fuse/breaker box with a screwdriver, breaking off all the tabs. But they did it back in February, going to be hard to prove it now. Unless it happened at the factory
Old 05-23-2007, 12:30 PM
Crash ?'s Avatar
POP!!!!!!!!!!!Was that your HEAD?????Another genius among us......PLEASE!!!If your tires say max PSI is 45,why would anybody run at 50 PSI????Do U know what MAX means????Lower your PSI 2 between 36 and 38 PSI before U KILL YOURSELF OR OTHERS.....U will also find that your trucks ride will improve...
You sure are one angry and sarcastic little person aren't you..???
Reasons for 50PSI.. Better fuel mileage.. Yes, it will go up some when there's higher pressures in the tire.. And yes, I understand MAX.. Which is why I stated I am running 45psi in mine.. If I was overly interested in a cushy ride, I woulda got a caddy.. It's a 4x4 truck though.. Riding Rough is what they as supposed to do.. Even with the OEM Goodyears it was rough IMHO..
Rob
Old 05-23-2007, 01:58 PM
KeyZ,
Where did you buy yours and where do you get it serviced ?
I purchased both of mine at VERA but get them serviced at Williamson(lots closer) Service writter is Mike Sutherland. He bends over backwards to help...
Old 05-23-2007, 03:38 PM
Desert Dan's Avatar
The max PSI on tires is the pressure you should be running when the tire is at it's max weight limit.
There is no need to run 40-50 psi (in the H3's) when empty around town unless you want to beat your self up with a rough ride.
If my truck is fully loaded and I have a long highwy trip I may put 45psi in the tires. This is for load capacity, mileage, to reduce heat build up, better handling and safety.
Desert Dan
Jeep TJ Rubicon 2003
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
Old 05-23-2007, 06:25 PM
KeyZ,
I purchased both of mine at VERA but get it serviced at Williamson(lots closer) Service writter is Mike Sutherland. He bends over backwards to help...
Palm Beach Hummer, and it never been to any other shop for service since I bought it, only a local GM dealer that reset the tire senders before I had figured it out.
Old 06-06-2007, 11:41 PM
marin8703's Avatar
hey sorry to bring this thread back but got a question for those unning 35 toyo open country mt. I got my tires installed about a week ago and i've noticed that only the center of the tire makes contact with the ground. Its as if its over inflated. But it cant be over inflated because i ran them at 32-33 psi.
i know as they wear it will even out, but then the wear wont be even. Does anyone remember if this is how thier's were when they were new?
any advice?
thanks.
Old 06-07-2007, 01:29 AM
Mine did that........but they were overinflated.
Old 06-07-2007, 01:37 AM
Mr_Pat's Avatar
Mr_Pat Mr_Pat is offline
Mr_Pat is an unknown quantity at this point
Quick question on 35"..... I just bought a set of 5 rims and with no presure sensors or stems. Now I dont "need" the presure sensors right? Also I can just use normal stems right?
Old 06-07-2007, 05:05 AM
No you don't need the TPM sensors. But the computer will still be looking for them so you'll keep getting the SERV TPM message in the DIC.
Old 06-07-2007, 05:07 AM
what a suprise....just like your HEAD
Old 06-07-2007, 05:51 PM
Four pages for a simple question!
I put 50 psi......
Old 06-07-2007, 05:57 PM
for those of you who cannot read...
it says put 186 lbs in and make sure your nose is close when pumping in the air...
Old 06-07-2007, 05:59 PM
ChiHummer3's Avatar
Old 06-07-2007, 11:52 PM
Mr_Pat's Avatar
Ok one last question about 35? Do I need to crank up the TB in order to have them on the H3?
I plan on doing that but I am getting my 33" OEM's changed out on warranty repair and they just ordered the tires today and the guy says it will take 5-10 business days to come in and we are headed to MOAB on the 16th and I don?t want to mess with the TB and get the alignment till I get the OEM tires changed by dealer.
Old 06-08-2007, 12:00 AM
marin8703's Avatar
they fit under there without touching the tb. I have mine at 3 turns, it raises the front about an half and inch to and inch. Im not sure, but without any turns you might get a littel more rubbing than usuall, maybe not.
