  #41
Old 05-25-2007, 03:17 PM
Idaho-Hummer's Avatar
Idaho-Hummer is off the scale
Default Re: New Bilstein / Cognito Hummer H3 Leveling Front Shocks???
thanks for the links, bebe
Old 05-25-2007, 05:30 PM
SR1355's Avatar
SR1355 SR1355 is offline
Is this it Bebes...
http://www.suspensionconnection.com/...scon/1520.html
Paul M
SR1355
Old 05-25-2007, 07:03 PM
Originally Posted by SR1355
Yes and no, it's not a colorado spring but that is the right pack.....call Gilbert at Hellwig - 1-800-367-5480 and tell him you have an H3....he'll know which part #.
You can get them at JC Whitney too.
Old 05-25-2007, 07:06 PM
SR1355's Avatar
Thanks Bebes, your the best.....
Paul M
SR1355
Old 06-01-2007, 07:54 AM
Wisha Haddan H3's Avatar
Originally Posted by tomp
Okay, shocks are on and test drive completed. I drove it around for a while and what a huge difference! Big improvement over stock ride quality, even with TBs cranked!
Hey tomp, it's been a week .... do you still like the cognito's? I'm curious about body roll in turns, recovery after hard braking and shock response offroad.
Old 06-04-2007, 05:06 AM
tomp's Avatar
tomp tomp is offline
Shocks are great. Definite big improvement over stock even with cranks TBs.
The body roll increase that occurs with cranking torsion bars partly occurs because you are no longer resting on the frame mounted bump stops. The shocks then assist with the body roll from there. I wouldn't necessarily say that these new shocks improve this situation any as I do not feel they are stiffer than the stock shocks.
High Pressure charged shocks really do not do a very good job at keeping body roll under control.
If after installing these shocks, you feel like it's still an issue (for me it's not) I would probably extend the bump stops to where they touch the control arm as they do from the factory. This should also assist with nose-dive when braking.
Old 06-04-2007, 05:30 AM
What about the HD torsion bars??? They should help with teh body roll?
Old 06-04-2007, 06:45 PM
tomp's Avatar
not sure on that Bebe... would have to try it
However, I would think higher rate spring or TBs will place more demand on the shocks as the shock absorption rate of the shock will remain the same. This seems to me like it would worsen the body roll IMHO.
IMO, the best way to reduce body roll with cranked TBs would be stiffer sway bars and bushings, stiffer shocks and bump stops that touch the control arms like OEM. Keep in mind stiffer sway bars will reduce articulation. I wish someone would produce stiffer sway bars with quick disconnect links
Old 06-05-2007, 05:00 AM
Amstar was supposed to make some, but no sign of them on their new site
Old 06-06-2007, 01:17 AM
H3slate's Avatar
H3slate H3slate is offline
They are to the right of the shocks. I was also disappointed with how some of their accessories disappeared when they changed names.
Old 06-06-2007, 04:33 AM
Forgive my neeewbness, what are you supposed to do with the swaybar once you have disconnected it?
Are you going to Reno with the dealership?
Old 06-06-2007, 10:09 PM
H3slate's Avatar
Just let it hang there.
Are they going to Reno again? I haven't heard anything, but would love to go. I had a blast down there. I want to go explore Peavine some more.
Old 06-07-2007, 03:02 PM
Crash ?'s Avatar
Crash ? Crash ? is offline
I'm sure someone has thought of this, but has anyone checked with ProComp to see what they have that fits in the range of both untweeked T-bar and tweeked H3s..??
What range do I need to be looking at anyway..?? (That's NEED not what is stock)
Kinda fill in the blanks..
Front No T-bar adjust Compressed _____ +/- ____
Front No T-bar adjust Extended _____ +/- ____
Front T-bar tweeked Compressed _____ +/- ____
Front T-bar tweeked Extended _____ +/- ____
Rear Stock Compressed _____ +/- ____
Rear Stock Extended _____ +/- ____
Rear Shackled and Disco'd Compressed _____ +/- ____
Rear Shackled and Disco'd Extended _____ +/- ____
(Bebes knows where I'm going on those last two)
What shocks are known to work right in these situations..?? Manufacturers' and part numbers would be nice.. I'm thinking if we could get all this info compiled it'd make for a good sticky thread or FAQ.. Just add info to it as more shocks are located or new ideas about modifying the suspension are discovered.
Rob
Old 06-07-2007, 03:44 PM
Desert Dan's Avatar
Why do you think the travel would be different with tweeked Torsion bars?
If you raise the front end 1 inch with the torsion bars you get the same total ammount of travel up and down only your nuetral position is an inch lower so you have 1 inch less for the front wheel to drop (droop).
You really have to cycle the front and rear suspenion w/o a shock to see what limits the travel and then find a shock that fits.
With longer rear shackles you may be more travel and then you would need longer shocks.
Desert Dan
Jeep TJ Rubicon 2003
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
Old 06-07-2007, 05:34 PM
Well the fawking enlighten us then please!!! I'm serious, I have done SOOOO much freakin research, stuff like that doesn't come up in tech write - ups.
Help me understand.
Please
Old 06-07-2007, 07:16 PM
tomp's Avatar
Unless you are planning on lowering the frame mounted bump stops, the new shocks will need to "not only droop further down due to the raised TBs - but to also be capable of going upward to hit the bump stop on the frame". If this is not the case with cranked TBs, you will be hard bottoming the shock and they will blow quickly. The newly required shocks for cranked TBs need to collapse to at least the length of the stock shock and provide longer length overall. This is exactly what the Bilsteins offer.
However, with either the stock shocks or the Ranchos, this should not be necessary as they come equipped with internal and external bump stops. The downside to these to offerings is the stops limit the travel.
Old 06-08-2007, 11:59 AM
Crash ?'s Avatar
Oh yeah.. Good point...
Rob
Old 06-08-2007, 12:04 PM
Crash ?'s Avatar
So what are the specs on the Bilsteins..?? Full Compression... Fully Extended... The Ranchos..???
Rob
Old 06-08-2007, 01:11 PM
Crash ?'s Avatar
Found the info on the Bilsteins..
Part Number
BE5-6140-T5
Travel
6.65
Ext Length
18.42
Col Length
11.77
Shaft Dia.
14mm
Mounting
Stem/eye
Rob
Old 06-08-2007, 01:49 PM
Crash ?'s Avatar
Found these ProComps that MIGHT work on the front..
The KMX086 is listed for the H3 but it's specs are kinda short.. 15.5 - 11.02
The these are listed as generic shocks rather than for an application, but the specs are dang close to the Bilsteins, maybe better..
Part #s Extnd Comp Trvl Dia
ES1000 Shock
11851X 18.12 11.31 6.85 2
11951X 19.39 11.93 7.52 2
ES3000 Shock
31851X 18.66 11.52 7.14 2.36
Rob
