  #61
Old 06-08-2007, 03:06 PM
Crash ?'s Avatar
Crash ? Crash ? is offline
Default Re: New Bilstein / Cognito Hummer H3 Leveling Front Shocks???
There's a TON of Monroe shocks that fall in close to these specs too.. But they have quite a few different end mounts.. If it's worth anyone elses time..
Here's the list with dimensions
http://www.monroe.com/catalog_lookup...nsionChart.pdf
Here's the way to figure out what end mount you need..
http://www.monroe.com/catalog_lookup...StyleSheet.pdf
Rob
Old 06-08-2007, 04:21 PM
Desert Dan's Avatar
Thanks for the info on the shocks Crash.
I am also checking with KYB (Gas Adjust) on what shocks they have for an H3.
They are gas charged with Nitrogen and seem to work well off road and on the highway on my past vehicles (Toyota Trucks).
Maybe Old Man Emu will make some for the H3 since its now selling in Australia?
Desert Dan
Jeep TJ Rubicon 2003
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
Old 06-08-2007, 04:47 PM
Crash ?'s Avatar
I kinda wonder if they do and just don't know it yet...
Rob
Old 06-08-2007, 06:58 PM
So for those of you who have not kept up on the shock threads, there are few makers who actually make a shock for the H3
ProComp
Rancho (they suck hard)
Cognito/Bilstein
Fox
Edelbrock - maybe...
That's it.
Old 06-08-2007, 07:08 PM
H3slate's Avatar
H3slate H3slate is offline
Anybody have the part # for the fox shocks? It would be nice to compare specs of their racing shocks vs. the cognito/bilstein.
Old 06-08-2007, 07:30 PM
I'm looking for the specs now....BRB
Old 06-08-2007, 07:43 PM
Desert Dan's Avatar
No KYB shocks yet per KYB
I haven't found any info on OME and ARB
Are the Bilsteins gas charged?
Desert Dan
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
Old 06-08-2007, 08:37 PM
Crash ?'s Avatar
ProComp
Cognito/Bilstein
Fox
That's it.
But which of these was it you were telling me actually work CORRECTLY..???
Rob
Old 06-08-2007, 08:59 PM
They may have something that is the right length, but the problem is the mounting. The B/C are actually standard Bilsteins that Cognito modifies to fit the H3.
yes
Old 06-08-2007, 10:02 PM
Cognito and Fox....oh by the by, fox does make a set for the rear as well.
Old 06-08-2007, 11:28 PM
Fox Specs:
Chevy H3 Front 980-99-291-A 05-06' Stock 16"E - 11.5"C Emulsion $225.00
Chevy H3 Rear 980-99-292-A 05-06' Stock 24"E - 16" C Emulsion $225.00
http://www.polyperformance.com/shop/...&cat=34&page=1
Old 06-08-2007, 11:41 PM
H3slate's Avatar
Fox Specs:
4.5" travel
Thanks for the info Bebe. It looks like the cognito have more travel in the front shocks.
Found the info on the Bilsteins..
Part Number
BE5-6140-T5
Travel
6.65
Ext Length
18.42
Col Length
11.77
Shaft Dia.
14mm
Mounting
Stem/eye
Does anybody know the travel of the oem shocks in front? Thanks for all the info!
Old 06-09-2007, 12:10 AM
H3slate's Avatar
Edelbrock makes shocks for the H3. Here are the part #'s.
front: 33055
rear: 34055
http://www.edelbrock.com/automotive_..._chart-2.shtml
I am searching for some specs on these shocks.
Old 06-09-2007, 12:48 AM
From PBB:
Originally Posted by Beat95YJ
Edelbrock H3 shock is 15.67 extended by 11.08 collapsed giving 4.6" of travel.
The oem shock is 15" extended by 11.25 collapsed, giving 3.75" of travel.
Old 06-09-2007, 02:48 AM
H3slate's Avatar
Thank you my Queen!
Shock extended collapsed travel
OEM......... 15.0" 11.25" 3.75"
Edelbrock.. 15.67" 11.08" 4.6"
Fox.......... 16.0" 11.5" 4.5"
Cognito..... 18.42" 11.77" 6.65"
Rancho .....15.77" 13.43" 2.34"
I like the price of the Cognito's, and the extra travel, but would like to replace front and rear shocks so I leaning torwards Fox.
Old 06-09-2007, 05:49 AM
tomp's Avatar
tomp tomp is offline
Isn't the rear shock just a standard shock, so I don't see why Bilstein would not have a factory replacement for the rear to match the front retrofits offered by Cognito.
Old 06-09-2007, 03:37 PM
Thank you my Queen!
I'm ordering the Fox too!
Old 06-09-2007, 05:32 PM
Wisha Haddan H3's Avatar
Thanks for the specs. One way or another, that'll make it in the FAQ
