Old 03-26-2006, 07:01 AM
Huck BB62's Avatar
Well, the Sierra's in the shop. I've GOT to figure out a way to keep the rodents from getting at the wires. I'm shootin' 'em, poisoning them, you name it, they're screwin' faster than I can kill 'em!
Anyway, I had to go get a load of lumber so I took the H3 with a borrowed trailer. It was a trailer with no brakes. I had a little less than a ton on the trailer. The H3 does pretty well. It downshifted at every rise and when I got to the mountains with it, it was pretty much a 2nd gear, 3000rpm affair for twenty miles. It'll do the job. I wouldn't want to do it all the time. The weight of the H3 is evident in cornering, the trailer didn't push the H3 around very much. Stiffer shocks in the back and tires with a higher load range/stiffer side walls would've made it even better.
Old 03-26-2006, 02:51 PM
good info , thanx Huck
Old 03-26-2006, 03:52 PM
HuckBB62 - Good to hear about a real towing experience.
Yea gophers used to be a minor problem on my property. But my next door neighbor said that he has the ultimate bait/poison formula (proba bly illegal) and I haven't seen any sign of gophers for over 18 months. Fortunately he has not killed any other wildlife with the bait.
S.
Old 03-26-2006, 05:19 PM
H3wannabe H3wannabe is offline
H3wannabe is off the scale
On a weekly basis I tow a car trailer loaded with a car (and an occasional SUV) behind my H3 about 45 miles. I do have the auto tranny and the trailer weighs 1300 lbs. alone and has 2 axles, both with electric brakes. It does fine, you just need to get a decent run going before any large hills.
It does great with a car on the trailer; loaded with an SUV (such as an Explorer) is pushing it...but I have done it several times.
H3wannabe
Slate Blue, Lux, Auto, Cashmere Interior and Tow Package.
Old 03-28-2006, 05:58 AM
Huck BB62's Avatar
H3wannabe, where'd you mount your brake controller? I've got a Prodigy on my truck, I'm thinking about buying a harness for the H3, it's just that my knees would hit it anywhere that I'd put it.
Old 03-28-2006, 10:45 PM
lamric's Avatar
lamric lamric is offline
lamric is off the scale
Mothballs will drive away rodent and snakes.
"Crisis is the rallying cry of the tyrant".
-James Madison-
Old 03-29-2006, 01:40 AM
Grandman Grandman is offline
Grandman is off the scale
I tow this around from time to time . H3 does ok . placment of the towed rig is important for proper tungue weight . Northern Mi is rolling hills but no mtns to deal with .
2006 H 3
Old 04-09-2006, 01:56 PM
Huck BB62's Avatar
Grandman, where'd you mount your brake controller?
Old 04-09-2006, 03:14 PM
Chinkierol30 Chinkierol30 is offline
Chinkierol30 is off the scale
Cool setup but why tow a Jeep when you have a H3?
Old 04-16-2006, 11:03 AM
I mounted mine right above my right knee...but it helps that I have an automatic, which allows me to keep my seat set pretty far back. It also helps that I am only 5'8". My knee never hits it, but when my wife drives her knee does as she puts the seat WAY forward.
H3wannabe
