Old 06-13-2007, 02:21 PM
aflax24's Avatar
aflax24 aflax24 is offline
aflax24 is on a distinguished road
Default Rear Leafspring Mount Squeek
Yes, I know I only have leaf springs in the rear... I have been having some pretty bad squeeks coming from my rear leaf springs. Wondering if anyone else has same problem. Some days it's terrible and some days it doesnt happen at all. Sux, when I roll through a parking lot and it squeeks like an old cadillac...I am sick of people staring at me wondering why Hummer makes a squeeky product. WTFO? Anyone?
AFLAX 24Black H3' Adventure Package, Air Raid intake, Wet Okole Seat Covers, 35's, PCM
Old 06-13-2007, 04:03 PM
stagger_lee's Avatar
Default Re: Rear Leafspring Mount Squeek
Guess what, we all only have leaf springs in the rear. Get under there and clean the thing and grease it up. I dont think there are zerk fittings there so you'll have to improvise. Inspect the bushinds too while your at it. I squeak after I have palyed in the mud and dirt too.
White Collar Hippie
'06 Luxury Adventure
'99 Toyota 4runner 4x4
'71 FJ40
Old 06-13-2007, 04:34 PM
aflax24's Avatar
Yes, I know they are only in the rear...It was a joke, thanks for clarification. The squeek is still going on after I took to dealer for a cleaning and lube. There are no Zerk fittings so I would assume they just sprayed some WD-40 in the crack. Just wondering if others had this problem.
Old 06-13-2007, 05:07 PM
Desert Dan's Avatar
Off Road More often!
Can you tell if it is the rubber bushings in the spring eyes or from the leaves rubbing against each other?
Crawl underneath and have somebody jump on the rear bumper. If you can locate where the noise is comming from spray it with silicone spray!
Desert Dan
Jeep TJ Rubicon 2003
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
Old 06-13-2007, 06:15 PM
ha sorry brother. sorry its hard to get sarcasm on the forum. Desert presents a good point as far a metal rubbbing. Also I think sometimes the dealers will tell you they did something special and not do anything. I would do a good once over yourself. I also would go with something other then WD-40. It might affect bushings negatively. It will displace water, but not lube it for extended time. I dont have it so bad that it bothers me like you are describing, but it does occur and I just slap on some grease and I use a little injector deal I have to get it in there.
White Collar Hippie
'71 FJ40
Old 06-14-2007, 03:26 AM
SR1355's Avatar
SR1355 SR1355 is offline
It's called "Trail Creak"... those of us that are addicted to wheelin' know that it can be a debilitating affliction... we hang our heads in shame as we travel about town... but.... I have learned.... to accept my condition and wear it like a badge of honor....No longer will I avoid bumps in the road, No longer will I use the parking space closest to the road... I'm proud of the fact that I wheel, and DAMN the rest...
Seriously, beyond rebuilding the leaf springs not alot you can do about it.
Paul M
SR1355
Old 06-14-2007, 01:08 PM
aflax24's Avatar
Thanks for the suggestions guys.
Old 01-12-2008, 12:16 AM
OU812 OU812 is offline
OU812 is on a distinguished road
aflax24, I am in the same squeaky situation. Were any of these suggestions successful in any type of success?
Old 01-14-2008, 06:59 PM
yat74's Avatar
yat74 yat74 is offline
yat74 is an unknown quantity at this point
Question Re: Rear Leafspring Mount Squeek
Do you have the rear shock mount skid plates? I have them and I wheel and it creeks back there. As mentioned above, proud of it; just lube it.
The Goat
