Old 06-14-2007, 07:33 PM
410225 410225 is offline
410225 is on a distinguished road
Default remote start
Anyone installed one? DO you know if there is one that is just added unit to existing GM security system?
Old 06-14-2007, 08:59 PM
Default Re: remote start
Mine works as just a remote starter and does not interfere with passlock systems.
Old 06-15-2007, 06:10 AM
bobh002's Avatar
bobh002 bobh002 is offline
bobh002 is on a distinguished road
I had a code alarm 2 way security system, keyless entry and remote start installed in my H2 a week after buying it. Love the remote start and being able to light her up walking up in the dark. Plus its cool when I get in cuz the a/c has been cranking for a few minutes. About 320 bucks installed.
07 H2 with lots of bling... well, have some..more coming
Old 06-15-2007, 08:30 AM
HummBob's Avatar
HummBob HummBob is offline
I just upgraded to the Compustar Pro P2W9000FMR. It's COOL!! The tech at my HUMMER dealership set it so when I start it in the winter, the heated seats come on!! Around $600 installed.
http://compustar.org/
Up to 3000* feet of Range
This new CompuStar Pro 2W9000FMR remote has a built in clock, in-vehicle temperature readout, and battery voltage sensing. This system operates at a higher frequency to allow for greater range and battery life. Firstech engineers were the first to perfect 900MHz FM for vehicle security applications and we've taken this technology to the next level with the 2W9000FMR Pro.
*Range is quoted for U.S. models only. International models will differ in range.
Includes 1 x Two-Way and 1 x One-Way remote
View the manual for the P2W900FMR
Pro Remote Features
- Two-way paging remote
- New multi-color LCD (liquid crystal display)
- CompuGlow backlight
- Vibration and audible notification
- Clock display with alarm
- Internal vehicle temperature display
- Parking Meter timer
- Button lock
- Timer Start Mode
- Cold and hot starting with temperature
- Run-time indicator (extendable with remote)
- Turbo Timer (extendable with remote)
- Secure Auxiliary Mode
- Shock sensor on/off through remote
- Passive mode on/off through remote
- Valet mode on/off through remote
- Uses standard AAA 1.5 volt battery
Pro Alarm Features | P2W9000FM-A
Pro Starter Features | P2W9000FM-S
Pro Alarm/Start Features | P2W9000FM-AS
- Includes starter-kill relay
Battery backup capable
- External Siren (six-tone)
- Optional super bright blue LED
- Driver's priority unlock
- Ignition controlled door locks
- Includes dual stage shock sensor
- Secure valet switch
- Anti-Jacking mode
- Remote Paging System (can unlock vehicle via pin code)
- 2-auxillary outputs, expandable to 7 with Channel Expander
- 2-programmable inputs
- Selectable trunk release output
- Horn trigger output
- Includes anti-grind and starter-kill relay
- Factory Style Alarm, monitors doors and trunk
- Time start set on remote by user
- Optional external Siren (six-tone)
- Diesel timer built-in
- Manual transmission compatible
- Anti-Jacking mode
BLACK \'04 H2 LUX
BLACK \'07 ESCALADE
Old 06-15-2007, 02:26 PM
WHOSNEXT's Avatar
WHOSNEXT WHOSNEXT is offline
Pro Remote Features
- Button lock
- Timer Start Mode
- Battery backup capable
- Anti-Jacking mode
- Anti-Jacking mode
i have the same 1......works real good
Old 06-15-2007, 02:47 PM
great systems, you will love this one...
Old 09-07-2007, 03:10 AM
s_c5519's Avatar
s_c5519 s_c5519 is offline
s_c5519 is on a distinguished road
Thanks for the tips, just got the Compustar Pro P2W9000FMR on an '07 H2, paid $600 too installed with remote start...
Old 09-07-2007, 12:39 PM
KingVinnie's Avatar
KingVinnie KingVinnie is offline
KingVinnie is on a distinguished road
I've got the Viper 5900SST, love it.
You'll need a passlock bypass like this:
http://cgi.ebay.com/ws/eBayISAPI.dll...MESE:IT&ih=012
Uses databus.
Old 09-07-2007, 08:42 PM
mikejr's Avatar
mikejr mikejr is offline
geez....here I thought I was cool with the factory remote on the 08 H2, but it doesnt do anywhere near the stuff that the aftermarket ones do. It does sense the temperature and will fire up the a/c if it is hot and will fire up the heater and heated seats when its cold though.
What all does that fob do? Looks like it has all sorts of stuff on the display.
2009 H2 Silver Ice LE
Old 09-07-2007, 09:03 PM
obzidian's Avatar
obzidian obzidian is offline
obzidian is on a distinguished road
I got a G5 a while back. Has remote start, double killswitch and code entry. Evertime you drive off, put it into park and then back to drive.... or a door is opened will in drive.... if you drive away, it will require a code. If you dont enter the code, the motor will shut off, alarm will go off and there is NO WAY to turn here back on unless you enter the right code. Oh, if your battery dies, i had an auxilary horn installed that would go off if you try to cut its lead or your battery dies with the alarm firing.
Kinda overkill, but there is no way your driving away with my truck!!! You can defeat it your doing quick stops to a gas station or publics!
