Old 07-04-2007, 02:37 AM
Braveheart7's Avatar
Braveheart7 Braveheart7 is offline
Braveheart7 is off the scale
Default Tag Plate Brkt
Ok I have a 2005 H2 with the hard spare cover and where the tag goes it is a whole for the tag plate to sit in and the light above.
I want to use the spare cover to advertise. is there a brkt I can buy to move the tag to the left side around the bumper area and low enough not to hit the swing arm of the spare?
I seen one a few weeks ago but couldn't quite make out how it was attached.
thanks
Old 07-04-2007, 04:43 AM
trashguy's Avatar
trashguy trashguy is offline
trashguy is off the scale
Default Re: Tag Plate Brkt
you can use a bracket from earlier h2s that had the plate holder and light attached to the drivers side tow hook or if you dont use your hitch much you can use a hitch mount plate holder like mine.
white 03 lux-gone
black 06 lux sut
Old 07-04-2007, 07:38 AM
jmsspratlin's Avatar
Nice, didyou make that, or did you buy it? Also it doesn't look as though it has the light attached to it. Does your state require having a tag light? Thanks...and nice looking truck by the way.....jamie
Old 07-04-2007, 08:48 PM
trashguy's Avatar
you can buy them
http://www.etrailer.com/mm5/merchant.mvc?Screen=PROD&Store_Code=E&Product_Code =5443&Category_Code=FMH
i bought a liscense plate frame with a light on it,there always on ebay.
white 03 lux-gone
black 06 lux sut
Old 07-04-2007, 11:06 PM
WHOSNEXT's Avatar
WHOSNEXT WHOSNEXT is offline
how about like this?
Old 07-07-2007, 05:19 AM
I think it was at the drivers side coming off the bracket.
where could I get one?
pne here or at a hummer store or is there an after market one I could get?
thanks
Old 07-07-2007, 06:02 AM
you can buy them
Thanks a mil. That is kinda what I have been looking for. I'd like to show-off the rear spare instead of having the plastic thingy couver it up. I will get on ebay tonight and see if I can find one with the light. I believe its against the law to not have a lighted plate in Florida. Thanks again.....Jamie
Old 07-07-2007, 06:04 AM
Is that some sort of TV reciever on the top of your rig? Just curious...Jamie
Old 07-07-2007, 06:38 AM
I looked on ebay, and nothing. Do you have a company name or anything from where you got one with the light on it? Thanks....Jamie
Old 07-08-2007, 01:53 AM
WHOSNEXT's Avatar
yes it is.....satellite....good eyes
Old 07-08-2007, 03:06 AM
trashguy's Avatar
here ya go ,do a search for lighted plate frame theres more.you can run your wires through the hitch so you dont even see them.also try to get a hitch lock from pepboys ,so someone dosent walk away with your plate.
http://cgi.ebay.com/ebaymotors/LICENSE-PLATE-FRAME-LIGHTED-HOT-ROD-STREET-ROD-RAT-ROD_W0QQitemZ330142888708QQihZ014QQcategoryZ42613Q QssPageNameZWDVWQQrdZ1QQcmdZViewItem
white 03 lux-gone
black 06 lux sut
Old 07-08-2007, 03:39 AM
How would I incorporate that to work in the hitch...its just the plate frame? Also, how would I run the wires through the hitch? Thanks for doing research into this for me...I appreciate it....Jamie
Old 07-08-2007, 03:42 AM
Also, how did you get the center cap on the spare? If it is the stock spare carrier, it has a protruding metal piece that extends out that has the light fixture on the end. Did you somehow cut it down, or what. I hate to start cutting, but if I have to ...oh well. I have a pic I can post up if you are unsure what I am talking about. Thanks again...Jamie
Old 07-08-2007, 04:59 AM
trashguy's Avatar
heres the plate holder ,then you need the lighted frame.
http://cgi.ebay.com/ebaymotors/License-Plate-Holder-Adapter-for-Receiver-Hitch_W0QQitemZ220127302841QQihZ012QQcategoryZ3365 3QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
the lighted frame has the wires on it ,tap into the existing tag light and run the wires trough the
hitch from behind the bumper.
white 03 lux-gone
black 06 lux sut
Old 07-08-2007, 05:57 AM
Thanks bro....Jamie
Old 07-08-2007, 01:17 PM
WHOSNEXT's Avatar
Jamie i cut that metal piece off, if you look close you will see the backup camera in center of cap.
Old 07-08-2007, 05:25 PM
You know...I thught that dot was a reflection of something in the fore ground. Very nice indeed, however I couldn't cut on my wheels, but being a stocker, wouldn't be an issue. Well, I guess I could always order another center cap from the manufactuer. Thanks man. Also, what did you use to cut that thing? It seems pretty freaking thick! Thanks bro....Jamie
Old 07-08-2007, 11:58 PM
WHOSNEXT's Avatar
sharp hacksaw
Old 07-09-2007, 06:30 AM
sharp hacksaw
Got some metal cutting Dremel bits tonight, hopefully it'll work.
