07-08-2007, 12:03 AM
Clutch Pedal
Anyone with manual trans have any problems with the clutch pedal.....I have noticed my pedal has become "loose". The amount of freeplay is good...its just that the pedal seems loose...I can move it side to side about a 1/2". And when I'm shifting after the shift when I take my foot off , it does not come right back, it sticks a touch . I did not notice any loose tension springs or loose bolts....
07-08-2007, 01:44 AM
Re: Clutch Pedal
I haven't noticed anything like that, but I've only had her for a couple of months.
07-08-2007, 02:25 AM
Re: Clutch Pedal
I've had no problems with mine, and I have over 26000 miles on it. Take it in before it becomes a real problem.
07-08-2007, 01:45 PM
Re: Clutch Pedal
If someone has the shop manual, can they scan the page with the clutch pedal part explosion and put it up here....Thanks very much...
07-08-2007, 08:26 PM
Re: Clutch Pedal
8300 miles on mine with no probs.
07-08-2007, 08:29 PM
Re: Clutch Pedal
Hope this helps.
07-08-2007, 10:08 PM
Re: Clutch Pedal
After 34K miles, my clutch pedal is normal... But I do have problems getting into gear at times.... I have to roll sometimes to try to get it into reverse...
Mercedes-benz Technician
07-08-2007, 11:37 PM
Re: Clutch Pedal
thanks for the scan...is there an explosion of that clutch pedal unit....
07-09-2007, 12:31 AM
Re: Clutch Pedal
That was the best page I found in the Helm manual.
07-09-2007, 01:06 AM
Re: Clutch Pedal
OMG! I have 2200 mi on my 07 and just looked under my dash, I HAVE NO CLUTCH PEDAL! you think warranty will cover it?
"He who fights fair, has no tactical skills"
2007 H3, Traded the H2, Custom grill guard, Warn winch, Custom roof rack w/ 4 KC lights and High Lift jack, Custom under body protection, Gibson cat back, Volant CAI, Throttle body spacer, Custom rock rails, Full audio system, Air, More to come!
GOD BLESS AMERICA AND OUR ARMED FORCES!
RLTW!! you get it if you get it.....
www.operatorsedge.com
www.hummeraccessories.cc
07-09-2007, 06:48 AM
Re: Clutch Pedal
x2
The clutch is fine ... it's getting through the gates that's hard. First gear can be difficult too. Reving to 2500 (clutch in of course) helps to get it in gear. Then you can clutch out and pull forward normally. It's like the synchros are already worn out. 8000 miles seems awful early tho.
