Old 07-10-2007, 05:53 PM
410225 410225 is offline
410225 is on a distinguished road
Default water leak
Well, It rained hard this Sunday and I had water on my dashboard assuming this was from the new gasket that was set from glass company. So called glass company to come out and reseal. Well, stupid of me, when the glass installer was suspecious and inspected, the water was coming in from the roof cablights. There are no insulation or no gasket between the cablights and the roof. Does anyone had this problem? Is there a gasket that can be purchased?
Old 07-10-2007, 06:12 PM
mikejr's Avatar
mikejr mikejr is offline
Default Re: water leak
Do a search on the forum, I know I've read about this in the past, but I cannot recall what the fix was.
2009 H2 Silver Ice LE
Old 07-10-2007, 06:56 PM
Silicone gasket seal is in your future.
Old 07-10-2007, 07:30 PM
if you installed them, clear caulk is quick and cheap....if they are factory/dealer installed take it back and have them take care of the water leak as well....
Old 07-11-2007, 06:46 PM
iccon's Avatar
iccon iccon is offline
iccon is on a distinguished road
Do you have a sun roof
Old 07-11-2007, 06:52 PM
iccon's Avatar
If you have a sun roof I was told by GM tech that the drain hoses inside the window frame get blocked then start to leak on to the dash they need to be kept clean.
Old 07-11-2007, 07:33 PM
I used the black RTV.
Old 07-11-2007, 07:40 PM
jmsspratlin's Avatar
Where on the dash was the leak? I had my entire window replaced due to the glass company stating that the window put in it previously was not a true fit. So....$300 later I now have a whole new window. I probably just got taken for a fool...
Old 07-11-2007, 08:48 PM
What was pooled on the top of the flat spot on the passenger side. Also, some of the water was trickering for the overhead console home link button and lights.
I went home and poured litle bit of water around the cab lights with the overhead console taken off. Sure enough, water just runs right through the cablight and trickers down.....
I am going to take out the front center three cab lights and plug them with flush rubber plugs and black RTV it since I do not like the cablights in front
Old 07-12-2007, 01:38 AM
lonePalm's Avatar
lonePalm lonePalm is offline
lonePalm is on a distinguished road
Im glad you had this problem, No offense I'm having the same issue and it has just happened on an off for the past month and it is coming out of the home link area. That small hole there acts like a little drain, Damn thing! Now I know what to do to fix it.
Drive fast and Beep the horn!
Old 07-17-2007, 03:43 AM
mdoyle mdoyle is offline
mdoyle is on a distinguished road
Remember- anytime you have your windshield replaced, tell the glass company NOT to use the lower factory glass positioners or else you'll end up with a long horizontal crack weeks or months down the road.
There is a TSB for this but I don't recall the number off hand, print a copy and give it to them to save a lot of hassle later.
Old 07-17-2007, 11:36 AM
Are you referring to a crack in the windshield itself, or in the sealing? Thanks for the info...Jamie
Old 07-17-2007, 04:15 PM
Well, I have RTV'ed the cab lights but I am going to remove all three amber center cablights. I have found flat button plugs for all three lights. I will be removing and sealing them. I will post a pic when I am done.
Two sizes are needed to plug. 3/8" (6) and 1-1/4" (3) and clear RTV.
Old 07-17-2007, 10:39 PM
The windshield itself will develop a horizontal crack that begins at the stress riser created by the factory glass positioners. Here's the old post from Klaus 2/7/2004:
Document ID# 1363441
2003 HUMMER H2
Info - Guidelines to Prevent Cracks in Replacement Windshields #03-08-48-004 - (08/01/2003)
2003 HUMMER H2
This bulletin is being issued to advise dealers regarding correct replacement of the windshield.
After removing the windshield, there will be two plastic blocks visible along the lower edge of the windshield opening, each located near the windshield wiper arm transmission spline. These blocks are assembly aids used only when installing the windshield at the plant. They must stay in place so as not to open a hole where they mount. However, upon installation of a replacement windshield, care must be taken to assure that the glass does not come in contact with the blocks.
After applying the urethane and positioning the windshield, leaving an air gap (3) of 1 mm (0.040 in) between the block (4) and the windshield (2) , compress the urethane only as much as necessary. This will assure that the glass does not come into contact with the blocks. If contact is made with the block, body flexing may cause the replacement windshield to crack. Cracks along the bottom of the glass are an indication that the glass is contacting the blocks.
Tape (1) the windshield in place. Do not remove the tape until the adhesive cures.
Important
When subletting a windshield replacement, provide a copy of this bulletin to the persons involved in the replacement.
Old 07-21-2007, 11:08 PM
Devis1957's Avatar
Devis1957 Devis1957 is offline
Devis1957 is on a distinguished road
See my post "Another Water Leak Thread". Your leak may be coming from the roof seam like mine was.
