  #61
Old 06-11-2005, 04:16 PM
Originally posted by md_sailor:
You Guys have got to see this bad boy.
http://getdieselpower.com/my01dmax_files/horn/index.htm
That thing will blow some air! Someone had a set of 5 Nathan's on their truck. It was posted a loooong time ago. Wonder what that sounded like.
Old 06-11-2005, 04:30 PM
md_sailor's Avatar
md_sailor is off the scale
Would'nt point them downward you would end up jumping Sh*t!
Old 06-11-2005, 04:38 PM
This is not a pic, but will tell you something about it:
Originally posted by unaslob:
an intersting BTW... on train horns.. if you are going to install a REAL train horn, as in one that came off a train, depending on the horn, that is a FEDERAL offense, and it carries a 10,000 dollar fine!! I know, b/c I had to look into it.
I bought a Nathan K-5-H, very large, very loud 5 chime horn, it accepts a 1/2 pipe for air. I purchased a 135PSI 25 gallon aircompressor for it. ran a 12 foot 1/2 inch pipe to it with a ball valve at the compressor end... now the horn can operate to 140PSI, with custom ear plugs and noise canceling flight headset... I can still only get it upto about 100PSI without being physically hurt. it is incredible.. it can be heard over 5 miles away!!! there are a number of companies that make 'train horns' but they are not off of a locomotive or ever intended for one.
http://elcova.com/groupee/forums/a/tpc/f/5106011751/m/342601...606037674#4606037674
Old 06-20-2005, 10:35 PM
Dan Dan is offline
Alright, I finally got mine installed and working correctly. These things kick ASS! The sound vibrates the whole truck.
A few things:
You'll need a 3 gallon tank minimum. I bought a 3 gal and its good for a couple good beeps. Anything smaller and it will empty out too quick.
Get some high pressure line. Mine blew a hole the first time running up the tank. I ended up with 2 10' braided stainless hoses from home depot that are good for 1400psi. The SS will help with the heat in the engine bay, rubbing on whatever, etc.
So far they are a lot of fun. I scared the **** out of two kids who thought they'd be funny and play chicken with me. Those kids jumped to the sidewalk and wiped the smiles off their faces REAL quick! Now the fun begins....
Highly recommended!
Old 06-21-2005, 01:32 AM
Very nice Dan. I think I heard it all the way over here... Oh hold on, that might be mine.
Old 06-21-2005, 02:35 AM
Pics please. You too, Dennis.
Old 06-21-2005, 10:21 AM
Dan Dan is offline
I'll post some pics later tonite.
Old 06-21-2005, 08:53 PM
Paul L Paul L is offline
Paul L is off the scale
now this is a set of horns!!!
http://www.carpentryasanart.com
Old 06-22-2005, 02:55 AM
Huh? Must be something wrong with my monitor.
Old 06-22-2005, 03:24 AM
JMV1210 JMV1210 is offline
JMV1210 is an unknown quantity at this point
DAN how loud are the horns in dbs? I know the real wheels is 130 or 135 dbs? Can you post a link to where you got the horns?
Old 06-22-2005, 09:27 AM
Dan Dan is offline
Yeah Ken, I know! I'll do it tonite. Got busy last nite and forgot.
J - They are the LiteGlow train horns. The website says 142db @ 120psi, but the box the horns came in said 152db @120 psi. The compressor/tank combo that came with the kit is a POS and broke. I bought a Viair compressor and a 3 gallon Firestone air tank which pressurizes to 150psi. So depending on which db rating listed, and adding an additional 30psi, they're probably about 150-160db.
I bought the kit from Sound Innovators in Miami. The Viair from a local guy, and the tank from http://www.TruckSpring.com
Old 06-22-2005, 09:45 AM
Dan,
Would you suggest to only buy the TRAIN HORN (by itself) and get the cables, compressor, and tank separately or do I still need to get the COMPLETE TRAIN HORN SYSTEM.
How much more did the viair compressor and the tank (together) cost you?
Does the train horns mount to the firewall, with utilizing one of the hood latch bolts to secure it? How is it mounted? Is everything under the hood? (compressor and tank)
I listened to the MP3 file, and the sound bite on the website you listed. Now that you have them and heard them in person, do they sound exactly like a train horn?
Joe
Old 06-23-2005, 09:29 AM
Dan Dan is offline
If I were to do it again, I would buy the horn itself and get the tank & compressor separate. The compressor/tank that comes with the "complete kit" kinda sucks. Its noisy, like one of those portable compressors that plug into a cigarette lighter.
The compressor with pressure swich cost me $160. Its a Viair 280C. Much quieter and has rubber mounts. It also has a remote air intake and filter.
The tank was $42 here: http://www.truckspring.com/airspring...oduct/9127.asp I got the 3 port but ended up plugging the center one. So figure on $200 for the tank & compressor.
I bought some angle iron and added to the mounting bracket. I have it attached to the firewall with 2 self tapping screws. The horn juuuust fits in there so even if it came loose it wouldnt go anywhere. Its that close.
The compressor & tank are in the jack compartment in the bed. There's no way the tank is fitting under the hood. The compressor probably could, but I wanted them close to one another. There appears to be room to mount everything under the truck just above the rear axle, but take some measurements beforehand to be sure.
I'd say they are very close to a train horn. They don't pack the same punch as a real locomotive horn, but the sound & tone is defintely there. The real ones have a large diameter feed and use a ****load of air. Way more than would be practical to get working on an H2. BIG tank, etc.
They are definitely loud though and the fun factor is high.
Old 06-23-2005, 09:31 AM
Dan Dan is offline
Old 06-23-2005, 12:41 PM
Hey, I don't have that little storage area. Besides, I don't thing the 5 gallon tank I have will fit there. Is that 1/4 inch line? It looks larger.
Old 06-23-2005, 01:11 PM
Dan Dan is offline
Yes, 1/4" line.
Old 06-23-2005, 01:31 PM
Dan Dan is offline
These guys sell a slimline 3 gallon tank. That might work out better mounted under the truck.
http://www.ckcustoms.com/index.php?cPath=24_29&osCsid=3...60407dd819c8745f0 f52
Old 06-23-2005, 01:39 PM
Daniel his horn it sounds like a train..
I can see his red tail lights, my ears are in pai..een..oh and...I can see Daniel waving goodbye...
God, It looks like Daniel..and my eardrums in my eye....
Old 06-23-2005, 07:08 PM
Dan Dan is offline
