07-13-2007, 12:47 AM
Re: My h2 and water
actually it was a few days after this water hole event i heard these two thuds.........i pulled upto a light and heard them at idle and havent heard them since........ sounded similar to when a engines misses.....
water in the gas maybe?
He who is not courageous enough to take risks will accomplish nothing in life.
07-13-2007, 12:52 AM
Re: My h2 and water
http://www.badthumper.com/videos/partone.wmv
another vid of me and the water!!!
feeling like a fish
07-13-2007, 12:54 AM
Re: My h2 and water
Wow.
Ok, obviously you don't know very much about how four wheel drive works.
I predict even more damage in the future.
It's cool you are wheeling the rig, but if you don't know how it works, you WILL find out.
07-13-2007, 01:06 AM
Re: My h2 and water
swoffy....just be aware of the fact that the air intake to your engine is bascially about 3 inches from the level of the water you were in and had you gotten any deeper or a wake from your passing through the water came up higher you would have ruined your engine. Like others have said....Hummer gives you a max ford depth...if you go deeper things are going to happen.....and those things aint cheap to fix.
Its a Hummer....which means its very capable off road, but it does have its limitations...
Great vid by the way.
2009 H2 Silver Ice LE
07-13-2007, 01:10 AM
Re: My h2 and water
more damage......
well thats fine to........maybe thats why i posted a question here?
anyways ....... i actually wheel mine unlike most !!!
i dont loose sleep over it either!!!
if it breaks it breaks............just wanted a heads up here to possibly catch some damage before it happens.......
07-13-2007, 01:12 AM
Re: My h2 and water
Thanks,
i wondered where the intake was........
ill change the fluid and stay outa the deep water for the future......
seems i may have gotten lucky
07-13-2007, 01:21 AM
Re: My h2 and water
When you tip up your hood, look on the passenger side above the front wheel and you will see where the air intake is. Now compare that to the first video that you had on the post and you will see on the drivers side where the water level was...like i said...inches away from damage.
Just know the machine and its limits and you will be fine if you dont exceed those limits by too much.....In the immortal words of Dirty Harry...
"A man's got to know his limitations"
07-13-2007, 01:31 AM
Re: My h2 and water
thanks for the advice mike......
how about a do it yourself for all these fluids?
be sweet if i could change myself so i could do more often.......
i seem to get into water and mud often during the summer months
i also thought at one point i got a little bog from the motor in that water........ is it possible to take in a bit of water with no damage?
07-13-2007, 01:39 AM
Re: My h2 and water
well one can do most anything oneself if they have the knowledge and tools. Lots of great people on this site with way more mechanical know how than me...ask around I am sure they'll help you out with that question.
I really dont know what the tolerance of the H2's engine is with respect to water getting into it. I would suspect that it isnt going to tolerate too much water.
07-13-2007, 01:44 AM
Re: My h2 and water
Its runninng fine except them two little thuds i heard today......
ill change the fluids and see what happens........
maybe a grand master will read this and give me further idea's or suggestions to look into.....
either way...... the trails await me!!!
07-13-2007, 01:51 AM
Re: My h2 and water
you didnt happen to run over a Prius today...that might have been the thuds.....LOL
07-13-2007, 01:53 AM
Re: My h2 and water
lol......
getting fluilds done on saturday morning.......
07-13-2007, 01:55 AM
Re: My h2 and water
well I gotta sign off here....have a few more hours of work this evening....much to do before we leave for vacation!
Enjoy the wheeling and stay dry
Mike
07-16-2007, 05:41 AM
Re: My h2 and water
After reading this thread, I'm curious. If you suspect water in the diffs, is there a way to check it for sure? Does the diff lube and the water seperate to the point you can drain the water out the bottom or is flushing the only option?
Also I see the hummer website says 20" is the max depth for a H2 in water. Is that generally what you guys limit it to? So far, all my offroading has been rocks and trails, haven't had much mud yet.
I generally don't take my H2 in for service, I want to do it myself, if possible. My service rep told me that I'm the only H2 owner he knows of that changes his own oil. I thought that was odd.
David
2005 H2 Adventure, Nav, Sunroof
07-16-2007, 07:57 AM
Re: My h2 and water
David
Very odd indeed. I try to do a majority of the work myself as well.
07-16-2007, 03:21 PM
Re: My h2 and water
My H3 Water Story in the thread below:
In short, I had my rear diff, and the whole backend of my truck under water for over 30 minutes, much longer than you. My damage was water seeped into the gas tank solenoid valve, located on top of the tank putting it above the 24" fording depth for the H3. The water contaminated my system so I staled out and was deadlined. The oil weight in the diffs are very heavy and are designed to keep out water, I had the dealer check during my repairs and reported them to be in good condition.
I think if you had water in your truck you'd know. If you've already pushed a tank of fuel through it, I'd say that's not your problem. Go ahead and run a cleaner through it just in case.
Did you check your air filter after battle.. was is moist/damp?
http://www.elcovaforums.com/forums/s...ad.php?t=27492
07-16-2007, 04:57 PM
Re: My h2 and water
great vids and stories....think maybe a couple of you need boats....
07-17-2007, 12:55 AM
Re: My h2 and water
That boat don't float.
07-19-2007, 08:56 PM
Re: My h2 and water
Originally Posted by Captain of the Titanic
Com'on guys... Did no one learn from my mistakes...
When Hummer says 24" water depth they mean it. add an inch for the 37s...
If the water comes in, which it will, it shorts out everything. One of the main processors is on the floor under the passenger seat.
I know. I had water up to the seat cushion on the passenger side of my previous Hummer, an H3, and it shorted out everything to the point where my insurance company totalled it.
Also, just for your info, if you are going to do this again:
1. hit the hill with some momentum
2. hit it a little to the left or right, then steer across it. You won't be in the holes that way.
3. Make sure you are locked and in low 4.
4. You forgot to cover the jeep with mud as you went by.
5. Why are you slumming with jeeps, anyway?
6. Don't publish your failures, only your successes. I want to see you make that hill, not puss out!
Anyway, be careful. A dead Hummer is a terrible thing....
Yea Captain you should know about too much water + hummer = death.
Also looking back now, arnt you pretty pissed about everybody calling you an AE in your sinking thread?
My cars:
Lamborghini Murcielago
Supercharged Viper 800 HP Special Edition #49 of 50
Porsche Boxster S
My Hummers:
08 H2, 22 in rims, 6 HID lights, 20 in TV with DVD
4 H2 limos 3 have lighted dance floors + ceilings, 1 has Zebra interior 24-26 passengers
H2 Limo 26 pass lighted dance floor (sold)
H2 Limo 24 pass (sold)
03 H2 (sold)
H1 Open top (sold)
FirstClassLimos.net - H2 limos and party buses in OH & PA
my car collection
07-20-2007, 03:27 PM
Re: My h2 and water
Yep... All I've tried to do is make sure that no one else knows the joy of a dead Hummer.
I still don't know why my H3 took on water so quickly. Maybe is was the angle is was at putting torque on the door seals. All I know I was is was in the water for 2 minutes or less while my buddy rush up, hooked up a strap and got me out.
Oh Well. I wouldn't have known the joys of a H2 if I had not killed my H3!!!
1968 Mustang GT convertible
