Old 07-20-2007, 03:07 AM
trailerpup's Avatar
Default TPM Service Warning... a new twist.
Have not found this from searching....
I have had my H3 for about 2 months with 3k on the odometer. When I am driving around town I never see the TPM warning all week long... but when I hit the freeway, not less than 5 miles at speed and the "Service TPM" light comes on and stays on. I get into the next town, shut the motor off and fire it back up and drive around, no TPM light. Then back on the freeway, 5 miles at speed and here comes the TPM light. This is like clock work. I wonder what the deal is??? Why would it do it when the tires heat up, and not while driving around. Are my tires filled with too much air and when they heat up the increased pressure is triggering the TPM. I thought "Service TPM" meant there was a bad sensor and "Check pressure" was for a low tire? Remember, my warning say "service TPM." Thanks for any tips!!
Old 07-20-2007, 03:14 AM
Default Re: TPM Service Warning... a new twist.
You are correct. I'm guessing its a bad sensor. Take it to the dealer.
But, out of curiosity, what is the cold pressure in the tires?
Old 07-20-2007, 03:31 AM
trailerpup's Avatar
The 4 on the ground.... 2 at 32psi, 1 at 33 psi, 1 at 34psi. Spare was 32. They all read 32 now. I'll see what happens tomorrow. By the way 35 Mud T/A on Adventure "stock" rims. Thanks.
Old 07-20-2007, 03:57 AM
There's your problem. They should be at around 37 PSI cold.
Old 07-20-2007, 04:19 AM
fourfourto's Avatar
I think there set to go off at 32 lbs.
Usually during the winter it goes off and cold psi is 32 lbs in 1 tire I fill them to 35 lbs(33 inch) and no problems.
Old 07-20-2007, 04:35 AM
marin8703's Avatar
i run around 32 on my 35s toyos and no problem. the weird thing with pup's problem is that it only comes on at higway. it should be the other way around. its probably bad sensor that cant make the proper measurement. sounds like a dealer thing if possible.
Old 07-20-2007, 06:43 AM
lance-n's Avatar
lance-n lance-n is offline
lance-n is off the scale
move to a warmer climate
they will never go off!!
ohh, sorry---no freeways here either!!!
White, Adventure, Chrome Billets, Black Leather
1995 White mint OJ mobile (full size Ford Bronco) - sold
2007 Silver Nissan Armada - wifemobile
2005 42' Tiara Sportfisher - Tournament Rigged and 40 knots!
Old 07-20-2007, 12:07 PM
4 sale ... 2 homes in Miami
and we have freeways
Old 07-20-2007, 03:19 PM
lance-n's Avatar
we have a home for sale here in cabo
great place, nice ocean view, great pool, nice yard, close to surf and town.............
we need more hummers here
Old 07-20-2007, 03:52 PM
Viet Nam Vette's Avatar
My Manual says for "2007" H3.. 35 PSI all around with the ZM6 off road Suspension and 33" tires. Any thing lower will trip the TPMS system.
Old 07-20-2007, 04:52 PM
fourfourto's Avatar
Dam easy to check ,top off all tires to 37 cold psi (35 inch)
And see if it goes on.
I noticed it takes a mile or two for the light to go out after airing up.
Old 07-20-2007, 07:54 PM
trailerpup's Avatar
O.K. I will post the resulsts. Thanks for the tips for the TPM... and moving!!
And, here I sit, staring at the rain.
Oh well, that means more mud!!
