Old 08-12-2007, 12:36 PM
flyin6's Avatar
flyin6 flyin6 is offline
flyin6 is on a distinguished road
Default Torsion bar keys
When lifting my Z71 Suburban, which is a 1/2 ton model, I used the Ford Keyways.
The Hummer is essentially a HD Silverado, which I have never modified. Do we use the Ford keyways or the green Chevy keyways to get approximately 3" lift?
Ford keyways are $39 for the pair. Aftermarket stuff is $99 or more for the same thing. Anyone know for sure??????
07 H2 black de-chromed SUT
04 Z71 Suburban
03 Z06 Vette 440RWHP
01 SAS Supercharged Tundra
Old 08-13-2007, 07:53 AM
flyin6's Avatar
Default Re: Torsion bar keys
Sore subject or something???
04 Z71 Suburban
Old 08-13-2007, 02:50 PM
audiofetish's Avatar
H2's do not do well with Torsion bar lifts. You will have a lot of problems down the road if you crank them.
09 Challenger R/T
95 Heep Wrangler
90 5.Slow
99 HMC4 Sold
01 HMCO Sold
04 H2 Adv Sold
03 H2 Lux Totaled
HOPE Volunteer
Old 08-14-2007, 01:33 AM
tomp's Avatar
tomp tomp is offline
And just where did you hear that from? I actually cranked mine up and did it where it rides better than stock. I made custom lower shock brackets to allow the upper control arm to just barely touch the steel-tab-stop. Then I measured the difference between the foam bump stops and lower control arm, fabricated steel plate to take up that difference and inserted in between the bump stop and frame. Now I have more droop and still rest on the bump stops as it did from the factory. Topped it off with Cognito pitman & Idler kit and Rancho 9000 shocks and now bettwe then it was when it was new!
Old 08-14-2007, 09:04 AM
flyin6's Avatar
Possibly, if it is done incorrectly.
Incorrectly= just cranking
Correctly done= correct keys, which happen to be the 1/2 ton chevy green keys for the 3/4 ton crowd (us), Cognito upper control arms, longer shocks, and a fresh alignment.
Have run my Suburban for years cranked with narry a problem.
04 Z71 Suburban
Old 08-14-2007, 02:09 PM
Well obviously that is not just a Torsion bar lift. You can search any Hummer forum and find a lot of info on the cons of torsion lifts. I think what he was referring to was a torsion bar adjustment or keys without correcting the other suspension issues. H2s have a lot more weight than the trucks. I still think that you would be putting more stress on the suspension components that would cause some issue in the future, especially if you Off Road a lot. BTW, did you replace the upper control arms? I have been trying to find someone that has to see what the drive is like. Thanks for the info!
09 Challenger R/T
95 Heep Wrangler
90 5.Slow
99 HMC4 Sold
01 HMCO Sold
04 H2 Adv Sold
03 H2 Lux Totaled
HOPE Volunteer
