08-22-2007, 12:58 PM
What's makes the best Workbench Top?
MDF or Plywood?
As I finish my new garage setup - I'm finally building the 12" and 6" workbenches. I have base cabinets, but I need to put on a bench top. I'm thinking about a 3/4" plywood, covered by 3/4" MDF. Whaddya think?
08-22-2007, 01:46 PM
Re: What's makes the best Workbench Top?
What type of work will be done on your bench?
Assuming you will protect it...what will you seal it with?
08-22-2007, 01:58 PM
MDF or Plywood?
Use plywood and screw it down...
Plywood is more forgiving then MDF and with it being screwed down you can replace it easy as needed
08-22-2007, 02:41 PM
Originally Posted by lotus4s
I'd recommend post form countertops from Home Depot.
What is that? I walked around Home Depot last night and don't see what you're talking about. Are you talking about the pre-finished (laminated) countertops? The problem there is that they are all multicolored and pretty dark which make finding screws and small stuff difficult.
3/4" plywood then put 3/16" "eucaboard" that's what the brand is at home depot. Its a mdf board sealed on one side. Its a good surface for alot of types of projects and if it gets to messed up you can pull it off and get a new sheet for very little.
GO PENS
08-22-2007, 02:42 PM
I'll do all sorts of things on it, not a necessarily a specific purpose.
If it's plywood I will stain and poly it. If it's MDF, not sure.
08-22-2007, 02:55 PM
MDF or Plywood?
For teh metalworking you've been interested in recently, I would think a steel top would be better. Don't you tink?
08-22-2007, 02:56 PM
That's what I did and it worked great. Sanded between many coats and it was very smoth and real easy for clean up.
08-22-2007, 03:19 PM
stain and poly is the way to go. Also get some aluminum trim for the front and sides. THe edges of the bench seem to get dinged up and/or splintered...esp. if you're throwing heavier metal or other things on it.
08-22-2007, 04:14 PM
Do you know of anywhere that you could get some old bowling alley planks? If you want a tough bench top, alley planks are where its at.
1997.5 Black Slantback
The Sole Remaining God Father
-007=
08-22-2007, 04:30 PM
Stainless steel!
08-22-2007, 04:34 PM
I can;t believe you overlooked a crypto benchtop.
08-22-2007, 04:35 PM
I already built two movable, 1/4 thick top, metal work tables. This is primarily for everything else.
08-22-2007, 04:36 PM
Good point.
However, I do have a welcome mat that is 100% crypto. It's great for scraping your dirty boots on.
08-22-2007, 04:41 PM
I haven't heard that one before. I have heard of guys using regular hardwood flooring that was left over from installs.
08-22-2007, 06:16 PM
I wouldnt use MDF at all. It falls apart with the slighest bit of moisture from a cold beverage sweat in a short amount of time.
I would go in and buy a gray kitchen counter top cut to the size you need. It will be strong, attractive and water/moisture resistant.
08-22-2007, 06:20 PM
I'm thinking that's what I'm gonna do.
08-22-2007, 06:46 PM
For crying out loud it's almost 2:00pm already. Make a decision, you could have had it in already, bolted that singer sewing machine to it, and made yourself some panties.
GO PENS
08-22-2007, 07:08 PM
roflmfao
08-22-2007, 08:17 PM
MDF or Plywood?
As small as they are, I don't think it matters what you use.
I used a prefab counter top from HD. It's got a light grey to white background with colored speckles. It sits on stock white cabinets and is 6' long.
