Old 08-22-2007, 08:20 PM
Default Re: What's makes the best Workbench Top?
Don't forget to buy the end pieces that will finish the counter off. They iron on and then you have to use a trim router to finish it up.
Oh, and don't forget to get the pieces of wood that elevate the counter up, otherwise you won't be able to open the drawers.
Old 08-22-2007, 10:23 PM
Originally Posted by BKLYNH2
For crying out loud it's almost 2:00pm already. Make a decision, you could have had it in already, bolted that singer sewing machine to it, and made yourself some panties.
I don't wear panties when I'm in the garage.
Old 08-22-2007, 10:24 PM
I saw those. That's a waste of money. They are like $16 each.
Old 08-22-2007, 11:14 PM
BigPoppa1411's Avatar
what about the counter top they use in high school lab? That stuff is hard as freaking steel and can take lots of heat and is chemical resistant too.
Old 08-22-2007, 11:22 PM
Plywood over time will warp and bend.
Unprotected MDF will bubble and deform if you spill stuff like thinners on it.
The counter idea sounds good.
Home Depot has that Duracoat that you apply on old counters to make it look like fake marble. 2 part epoxy system. Maybe that will work?
But a nice work bench must have a nice felt fabric or thin industrial carpet on top.
Old 08-23-2007, 02:16 AM
Very EXPENSIVE, I use to sell it...
Old 08-23-2007, 02:18 AM
Only Canadimex plywood warps...
Old 08-23-2007, 02:24 AM
If your "SHOP" is for woodworking, home repairs, non-welding home hobbies plywood is the best...
It allows for screwdrivers, drill bits, chisels, saw blades etc to hit the surface and not do damage to the tool and again as said earlier if the surface starts to look chitty just replace it without spending a fortune.
Do you want the counter to be practical or are you looking for a rich mans ego trip. Its one thing to have pretty kitchen counters that you can sanitise and another to have a shop look like a shop...
Old 08-23-2007, 02:33 AM
ssgharkness020147's Avatar
They are the strongest work bench's I have ever seen. What you do is take the planks the lay them out upright (so the side of the plank is laying up), and then glue/bolt them together. If I did not have work benches from 50+ years ago that have tops on them as tough as nails, alley planks are what I would use.
I haven't heard that one before. I have heard of guys using regular hardwood flooring that was left over from installs.
1997.5 Black Slantback
The Sole Remaining God Father
-007=
Old 08-23-2007, 03:06 AM
Where do you think 80% of your toothpaste and 60% of your wood come from?
Old 08-23-2007, 03:09 AM
CHINA !!!
Old 08-23-2007, 03:17 AM
CHINA !!!
And I thought you had basic education.
CANADA.
Old 08-23-2007, 03:19 AM
Messsico!!
Old 08-23-2007, 04:09 AM
Messsico!!
CANADA.
http://www.msnbc.msn.com/id/18841928/
But enough about RYD and his fantastic world of wisdom. This is about your table.
Old 08-23-2007, 04:52 AM
HE'S right start with 3/4 plywood and after a few years another 1/4 inch layer and so on. The last time I used 1/4 oak and I always used aluminum edge moldg. Super job and cheap to renew and replace.Regards The Rebel
H2 REBEL lennyrebel
Old 08-23-2007, 05:54 AM
For teh metalworking you've been interested in recently, I would think a steel top would be better. Don't you tink?
Stainless>all
Old 08-23-2007, 11:20 AM
i'm always right...
Old 08-23-2007, 01:00 PM
Stainless>all
Nuh uh. Stainless tops look nice for a while, but they dent too easily.
Old 08-23-2007, 01:03 PM
SnakeH2's Avatar
SnakeH2 SnakeH2 is offline
Chicks dig plywood....
Where's WiFey?
Old 08-23-2007, 01:23 PM
Exterior glue ply 5/8. After it gets nasty add 3/8 toppers... always one side good.
