Old 08-28-2007, 08:40 PM
MattRoberts123 MattRoberts123 is offline
MattRoberts123 is on a distinguished road
Default Re: Squeaking Creaking Body / Frame Noise
Well after taking it to the dealer, and them doing whatever to the rear mount points, it is better... but I still notice something, which may be the cable thing you all are talking about.
The question is that I really haven't seen a detailed fix or solution to the problem...? Hell I don't even use my parking break, should I just remove the cable..?? or is there an easier more reasonable fix?
Carless... riding the bus... Trying to decide on which 08 H2 to get
Old 08-29-2007, 06:53 PM
IRA51's Avatar
IRA51 IRA51 is offline
Don't remove the parking brake cable,you will need it sooner or later . if you are up for a little witch hunt try spraying the cable with silicone spray the whole lenth of the cable and see if it stops . it could be the cable inside ,and not where it rubs the body or frame .if it is sealed than a new cable is the only solution and that should be covered under warentee.
A government big enough to
you have.
-- Thomas Jefferson
Old 08-30-2007, 11:37 PM
twenty2's Avatar
twenty2 twenty2 is offline
thanks for everyones advise on this! All fixed! No more creaking. It just needed some spray on the brake cable and... I ended up sraying all aroung the bushings and whatever else would be near or touching the frame. All quiet now.. Yipppeeeeee
Old 09-17-2007, 07:12 PM
Wink Re: Squeaking Creaking Body / Frame Noise
FYI, i took in the h2 for the creeking noise and the dealer worked on the front crossmember and all is quiet now...
tech sheet stated;
"Noisy front crossmember perform bulletin 03-08-61-002I
installed washers and torque crossmember."
2006 Yellow H2 Lux Series
Cognito Steering Support Kit
Cognito Idler Pivot Kit
Fabtech Steering Stabilizer
Fabtech Tie Rods
Power Slot Slotted Rotors
Hypertech Power Programmer
True Flow Foam Air Filter
Old 11-03-2007, 10:03 AM
jmsspratlin's Avatar
Thanks for this info
