09-08-2007, 01:59 AM
Top Radiator Hose - Plastic clip removal?
Any idea how to remove the top radiator hoses' plastic clips? Thanks
09-08-2007, 04:06 AM
Re: Top Radiator Hose - Plastic clip removal?
Photo, please.
09-08-2007, 04:10 AM
Surely you dont need a pic of this.....
It's the two large plastic clips that hold the top radiator hose tightly against the top of the upper fan shroud
09-08-2007, 05:19 AM
As you wish, I guess it will keep until the next time I'm under the hood. I was just trying to expedite for you.
09-08-2007, 03:39 PM
Anyone?
09-08-2007, 05:26 PM
Tomp , it is hard to tell you. But you need a tiny screw driver to compress the little tab from the top end of the clamp . The area you compress is inside the bottom end of clamp . When you compress the tab it will unhook itself from the bottom half of tab. Hope this helps. doug
09-08-2007, 05:28 PM
Let me try to make it more straight forward. Ultimately the top half of clamp pulls out of the bottom half of clamp when the tab thingy is compressed.
09-08-2007, 05:30 PM
what Dug said.....or a sawzall....
2009 H2 Silver Ice LE
09-08-2007, 06:33 PM
buy a new one ,50% of the time they can be reused . I just clip them off and change the hose and install a new one ,faster and less frustrateing .
A government big enough to
you have.
-- Thomas Jefferson
09-08-2007, 11:50 PM
Sounds like a wire tie. Guess I'll need to look.
09-09-2007, 03:48 AM
Thx Dug, worked like a champ!
