Old 09-13-2007, 11:13 PM
dkhummerh2's Avatar
dkhummerh2 dkhummerh2 is offline
dkhummerh2 is on a distinguished road
Default my a/c quit
Hello,
I have on 03 H2 with 44k miles. My ac quit blowing cold yesterday. I was wondering if there was any issues with this or if i just need to take it in and get it charged. It blows hot. Can't think of anything else that it could be than just needing a recharge.
thanks for you help
Darin Kaiser
Old 09-13-2007, 11:55 PM
MVR 155's Avatar
MVR 155 MVR 155 is offline
Default Re: my a/c quit
Check some of the obvious things first before paying for a recharge such as the fuse for the compressor (its got an electronically controlled clutch) and then check to see if the compressor is even engaging
1/4 mile: 11.661@118.86
2013 Audi S4
2002 Yamaha YZF R1 Blue/White
1/4 mile: 10.51@136
2005 Sea-Doo RXT
Old 09-14-2007, 01:11 AM
Dug Dug is offline
Dug is off the scale
check to see if the belt is still on the pump. My tension idler **** the bed and tossed the belt off.
Old 09-14-2007, 01:15 AM
KingVinnie's Avatar
KingVinnie KingVinnie is offline
KingVinnie is on a distinguished road
What they said, check compressor engaging first
Old 09-14-2007, 02:42 AM
mikejr's Avatar
mikejr mikejr is offline
are the other functions of the hvac control panel working correctly? I'd try the other things mentioned on the thread.
2009 H2 Silver Ice LE
Old 09-14-2007, 03:16 AM
dkhummerh2's Avatar
Yep is all works fine, just doesn't blow cold. The belt looks fine. I check the fuse on the side of the dash. Is that the fuse that you guys are talking about? just thought that is was odd with only 44k miles, but i guess it is 5 years old. Thanks guys for the tips, I will check them out.
dk
Darin Kaiser
Old 09-15-2007, 11:33 AM
Dug Dug is offline
If belt is on and pump is pumping when engaged , try adding some freon. Its not freon anymore , its N-12 or something. You can buy a can at Napa for $15. The can has a hose that snaps onto your condenser line , then push top of can and fill system. If a/c doesnt blow cold after that take it to a shop. Only do this after you have checked the fuses , reset the brain , and checked the belt is on. doug
