Old 09-20-2007, 09:35 AM
Default Water leaking in the rear
I had a little leak in the ceiling in the rear (right corner). Had it checked out and it seemed that the rubber sealing from the red rooftop corner light was used. That was the cause. We replaced the sealings from both corner lights and problem solved.
Just wanted to share this.
Frenzy
Old 09-20-2007, 04:39 PM
Default Re: Water leaking in the rear
Good to know! Thanks for letting us know!
1968 Mustang GT convertible
Old 09-20-2007, 11:08 PM
lonePalm's Avatar
lonePalm lonePalm is offline
lonePalm is on a distinguished road
Yeah I had the same problem with the front roof lights, replaced the gaskets no problems now!
Drive fast and Beep the horn!
Old 09-20-2007, 11:48 PM
Braveheart7's Avatar
Braveheart7 Braveheart7 is offline
Braveheart7 is off the scale
Talking Re: Water leaking in the rear
also check the rear wipre arm grommet, mine was leaking there. yo uonly notice it when you lift tail gate.
Old 09-22-2007, 07:30 AM
will do ! Thanks !
Old 09-22-2007, 01:14 PM
jmsspratlin's Avatar
Great thread...thanks for the info....Jamie
