Old 09-20-2007, 07:15 PM
dkhummerh2's Avatar
dkhummerh2 dkhummerh2 is offline
dkhummerh2 is on a distinguished road
Default lost power steeriing and braks
Hello,
Went offroading and lost powersteering and brakes. no lights on in dash.
any ideas
dk
Darin Kaiser
Old 09-20-2007, 09:25 PM
tomp's Avatar
tomp tomp is offline
Default Re: lost power steeriing and braks
Check fluid level
if full, take off cap and have someone turn wheel to verify flow of fluid is there
Old 09-20-2007, 09:30 PM
Yetti Yetti is offline
most likely the pump shaft failed.
Yetti
www.greatlakes4x4.com
www.wegotmud.com
www.glfwda.org
Old 09-21-2007, 02:52 PM
dkhummerh2's Avatar
the flow was limited, so went ahead and had a new pump put on. any ideas why this happened. I am running a whipple s/c. OUr my other stock parts okay for this application.
dk
Darin Kaiser
Old 09-21-2007, 04:30 PM
tomp's Avatar
Dry steering when parked? You should always try to be moving when you turn the wheel or it puts strain on PS system. Also, wide tires causes additional stress.
Keep tire pressure optimal when on pavement
Old 09-21-2007, 04:35 PM
tower's Avatar
tower tower is offline
I saw it happen once before in sand dunes where the driver (fool) was hauling ass downhill while braking and turning very hard. The next day he rolled over 3 times with his wife and 6 y/o daughter in the truck.
Old 09-21-2007, 07:41 PM
dkhummerh2's Avatar
Yeah,
I got into a situation I shouldn't have.been in the first place. I had to run the steering very sharp to the right while running the truck at about 5k, all this at an angle. It was all the driver on this one. Only had the H2 about 4 weeks, 2nd time in the shop. First one I broke my bottom ac belt. Just small things that I am more than happy to fix. Thanks for all your help and I will let you know if that fixes it. I sure hope so.
dk
Darin Kaiser
