Old 09-20-2007, 10:05 PM
CCMDoc's Avatar
CCMDoc CCMDoc is offline
CCMDoc is on a distinguished road
Default Re: POST YOUR STOCK RIMS WITH 35's!!!
Originally Posted by Russell-h3-alpha
Hey guys, the title says it. Ive noticed a ton of people with stock rims and the 35 inch tires, I love the look. So post up some of your favorite pic's of your truck with the factory rims and the 35 inchers. This should be a good thread! oh also if you could tell what kind of tires your running! THANKS!
This was my 07 Adventure with 315/75-16 BFG MT
Don't save the best for last, the smile for later or the "Thanks" for tomorrow.
Paul
'01 Esprit V8TT - intercooled, chipped and Quaifed
'08 H3Alpha Off-Road-315/75-16Maxxis Bighorns, grill&marker lights,+1 light Bar OEM Nav w/backup cam
Old 09-21-2007, 01:49 AM
LesC.'s Avatar
LesC. LesC. is offline
LesC. is on a distinguished road
Rubbing issues ???? Anybody ?????
2008 Black H3 Alpha, Lux Pkg, 33" MTZ's
Old 09-21-2007, 11:43 PM
Mudd's Avatar
Mudd Mudd is offline
Mudd is on a distinguished road
That's what I'd like to know.
Any BFG A/T's?
HUMMER, the Anti-Prius.
2006 Yellow H3
Who the heck is "RikRotorhead"?
Old 09-22-2007, 11:40 PM
H3slate's Avatar
H3slate H3slate is offline
In my research on 35's, the only rubbing is at full crank of the wheel (which you get anyways with the 33's ) and when completely stuffed. But I have not seen anyone tear off their fenderwells or have any carnage from the rubbing. There are even a few brave souls who have not cranked their torsion bars and had good luck with 35" toyos. (Green Lantern if I remember correctly)
There are some pics on here somewhere of a H3 with 35" bfg a/t, it looks good, but not as good as any of the mud terrains people have.
Old 09-23-2007, 04:22 PM
jmsspratlin's Avatar
Originally Posted by NEOCON1
toyos here
The green one looks almost like a Jeep
Old 09-24-2007, 06:42 AM
trailerpup's Avatar
What else? ... Mud T/A's. Picture taken at.... the outlet mall parking lot!!!
Old 09-24-2007, 03:25 PM
TXSUT's Avatar
TXSUT TXSUT is offline
Did you back out, or continue forward? If you went forward, any trouble?
Old 09-24-2007, 03:49 PM
fourfourto's Avatar
He had to go foward ,just a little twist ditch
gotta watch the steps though
Old 09-24-2007, 04:46 PM
Texas Red's Avatar
Texas Red is off the scale
A couple of questions:
1. Do the 35's generally need to have torsion bars cranked? What does this do?
2. Is there anything size-wise between the Adv 33's and the 35's worth considering?
Jim
2008 H3 Graphite Lux
Old 09-24-2007, 09:44 PM
1: 3 turns of the Tbars raises the front end up high enough to make room for the 35's to fit when aired down and your flexed up. Some truck require no cranking while I think a couple of truck here had 4 or 5 turns. You will also need a front end alignment when done.
2: 35's gove you more ground clearance and a little better AP and DP angles. = less smacking the bottom of your truck.
Old 09-25-2007, 12:15 AM
H3slate's Avatar
Nice pic! I love the look of the body color grill with the chrome H3x grill over it.
Old 09-25-2007, 01:23 AM
Never really liked the H3X guard, but it looks good on your rig.
Old 09-25-2007, 01:38 AM
trailerpup's Avatar
Yeah, I thought I screwed the pooch on that one, but the xGuard is growing on me. Thanks for the feedback.
Don't remember how many T-bar turns, but it sits at 24.25 inches hub to fender lip. Slight rub on sway bar when cranked full to the left. Fortunately mall crawlin' doesn't require airing down!!
Old 09-25-2007, 02:46 AM
Dave92270's Avatar
I'm currently in the process of shopping for tires too, and as far as your question no 2 goes, I see two other sizes in the lists (beside standard 285's, but they still will be some 33-33.5") - I'm considering those for myself because I'm not too excited about cranking the torsion bars out of factory specs, but I do like the look of 35's. So I'm undecided, do I want the 33's and keep close to stock handling and performance, or 35's with better off-road capability and killer looks, but on expense of somewhat out of specs torsion bars tension, and possibly some extra strain put on the suspension, and possibly bit worse daily ride (lower acceleration I can imagine for instance)?
Whether these tires are worth the upgrade from stock adventure Bridgestone 285/75/R16 is questionable, but I currently have low profile 32's (305/50/R20), so they look good to me, better then the stock 33's. These should fit stock 16" alloy wheels that I'm planning to buy from my dealer.
Toyo (Open Country A/T, 2-ply sidewall):
LT295/75R16 123Q OAD:33.39", rim size: 7.5-8.0-9.5, weight: 56.7 lbs
LT305/70R16 124Q OAD:32.68", rim size: 8.0-9.0-9.5, weight: 57.5 lbs
Toyo (Open Country M/T, 3-ply sidewall):
LT285/75R16 126P OAD:33.00", rim size: 7.5-8.0-9.0, weight: 68.0 lbs
LT305/70R16 124P OAD:33.00", rim size: 8.0-9.0-9.5, weight: 72.0 lbs
for comparison:
Toyo 35" M/T
LT315/75R16 127Q OAD:34.90", rim size: 8.0-8.5-10.0, weight 76.0 lbs
Bridgestone 33" A/T (stock adventure tire)
LT285/75R16 122/119Q OAD:32.9" rim size: 7.5-9.0 8.0, weight: 54.0 lbs
I?m still checking out the specs lists from other manufacturers (BFG etc), but the sizes should be similar.
I'm absolutely not an expert but looks like the M/T's are more rugged, more durable tires. I think they would be a better choice then the stock 33" Bridgestone A/T's. I kind of like the idea to mount the Toyo LT285/75R16 M/T (wish the M/T would have the 295 size available)? I?d keep everything pretty much within the factory specs, gain the 3-ply durability and overall puncture resistance, get the aggressive tread for off-road driving, and enjoy the apparently good looks? but yes, the 35?s?.I guess I will never make my mind, and will drive on my silly low-profiles until I?ll trade-in the car...
Old 09-25-2007, 03:00 AM
Mr_Pat's Avatar
Mr_Pat Mr_Pat is offline
Mr_Pat is an unknown quantity at this point
Old 09-25-2007, 03:15 AM
Texas Red's Avatar
Great lookin' rig! What roof rack is that?
Did you crank your torsion bars?
Jim
Old 09-25-2007, 04:37 AM
Mr_Pat's Avatar
Its a Rola, with the extention part, runs about 200 bucks. Yes I did crank the t-bar. I did turned it 3 times, then got an alignment
Old 09-25-2007, 11:43 AM
fourfourto's Avatar
Nice rack for the $$$ ,wouldnt it have better support if the crossbows were closer together ?
Old 09-25-2007, 01:46 PM
yat74's Avatar
yat74 yat74 is offline
yat74 is an unknown quantity at this point
Rausch Creek PA May '07
The Goat
Old 09-25-2007, 01:47 PM
yat74's Avatar
Talking Re: POST YOUR STOCK RIMS WITH 35's!!!
Love the Rola too.
The Goat
