Old 03-02-2006, 06:33 PM
JohnnyRPM's Avatar
JohnnyRPM JohnnyRPM is offline
JohnnyRPM is off the scale
Okay, so both of my license plate lights are out. Pullled the bulbs and they both look blown...all black at the tips. I replaced them both and still nothing. Checked the fuse charts and there's no license plate light specific fuse and all other lights/accessories are working perfectly. Then I checked the wiring schematics and it appears they're wired through the left and right parking and marker lamp circuits, which are both working correctly.
Anyone else ever have this problem?
There has been no liftgate body damage and no work done to the rear of the truck where wiring to these lamps might have been damaged or disconnected.
I have the IPCW LED tail lights but I don't see how that would make any difference. Other than these two damned lights everything else on the truck works perfectly.
Suggestions?
-John
Old 03-02-2006, 07:13 PM
Plug in the old lights and see if they work. If they do, then you kow it's the new lights.
Good luck, I hate electrical problems.
Old 03-23-2006, 12:31 PM
HOT BOI HOT BOI is offline
HOT BOI is off the scale
HOW DID YOU CHANGE THE BULBS? I HAVE A 2003 AND I TOOK THE SCREWS LOOSE AND THE PIECE DID NOT COME DOWN.
Old 03-24-2006, 04:04 PM
JohnnyRPM's Avatar
It'll come out...there are two screws on the sides and one in the middle. Once those are out, pull on the assembly to pop it out. Mine had some sticky foam material holding it in place that just pulled away when I removed it.
Old 08-14-2011, 05:45 AM
ScottTheBodyGuard's Avatar
ScottTheBodyGuard ScottTheBodyGuard is offline
ScottTheBodyGuard is on a distinguished road
Default Re: license plate lights out
i'm having the same problem right now. only my left license plate light is working and the right one is not. just installed new 194LL bulbs too.
did you ever figure out a solution to this problem?
-scott
Old 08-14-2011, 07:39 AM
NJ H2's Avatar
NJ H2 NJ H2 is offline
Uhmmm Scotty .... This thread is 5 1/2 years old
